Discuss
Dryer Will Not Heat
 in
Dryer Repair
Hello, and thank you in advance for the help! Brand: LG Model: DLE1001W Type: Electric I woke up to the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Will Not Heat
  #1 (permalink)
Old 03-06-2017, 11:18 AM
Junior Member
coreyhall is on a distinguished road
Default Dryer Will Not Heat
Model Number: DLE1001W   Brand: -other-   Age: 1 - 5 years
Brand: LG
Model: DLE1001W
Type: Electric
I woke up to the dryer not having any power. No lights, nothing. The breaker was not popped. I reset the breaker and went back to the dryer and it had power. I run a load and realize that it was not heating up. The breaker was not popped and there were not error codes.
I ran the diagnostics and got an nP error code. This means that the correct power is not getting to the dryer to run the heater element. It tells me to reset the breaker. I do. I come back and the dryer is heating and runs two loads and dries the clothes. It fails again after this.
The diagnostic says its an nP error again. I repeat the same steps, but this time it will not heat. I ran the diagnostics four times. It did come back with an error code of HS one time. Which means the humidity sensor might have been bad.
I don't believe it's my house's internal wiring as the breaker is not popping and nothing else is affected. The dryer still gets power, but will just not heat. Where do you think I should my attention first? Would the humidity sensor cause it to not heat? Or would the power run through the circuit board and perhaps something in there is spotty? I opened it up and it does not smell or look burnt. What do you guys think?
Related Models
 DLE1310W Dryer
Amana DLE231RAW DRYER- ELE
 DLE2512W Dryer
 DLE2514W Dryer
 DLE2515S Dryer
 DLE2516W Dryer
 DLE2532W Dryer
Amana DLE330RAW DRYER- ELE
Amana DLE330RCW DRYER- ELE
 DLE3733D Dryer
 DLE3733S Dryer
 DLE3733U Dryer
 DLE3733W Dryer
 DLE3777W Dryer
 DLE5932S Dryer
 DLE5932W Dryer
 DLE5955G Dryer
 DLE5955W Dryer
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
  #2 (permalink)
Old 03-08-2017, 05:44 PM
Senior Member
brobriffin is on a distinguished road
Default
On 220/240 circuit breaker it sounds as if (half) of the breaker has popped.
(By resetting it and it works for a while then stops gives me this idea)
Try replacing the circuit breaker to see if it is weak. This should fix your problem, If not let us know.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral Dryer Runs no heat in heat cycles, does not turn on in no heat fluff jennshuey Dryer Repair 3 11-19-2016 12:49 PM
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat darien685 Dryer Repair 2 08-24-2016 12:45 PM
Whirpool gas dryer won't heat already replace the coils and flame sensor and no heat Joseph1976 Dryer Repair 0 05-30-2014 09:00 AM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
