Discuss
Same temp on all settings
 in
Dryer Repair
My problem started with a blown thermal fuse. Which I replaced along with the high limit thermostat. When the fuse
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Same temp on all settings
  #1 (permalink)
Old 03-01-2017, 03:38 PM
Junior Member
Deathbywhirlpool is on a distinguished road
Default Same temp on all settings
Model Number: Ler7646jqo   Brand: Whirlpool   Age: More than 10 years
My problem started with a blown thermal fuse. Which I replaced along with the high limit thermostat. When the fuse went again I decided to look a little closer at my discharge temp at the outlet of the dryer which was a little high at about 168, but I noticed the mother was slowing to almost a stop. So I assumed that after a few loads the motor it may have slowed enough to cause the heat to back up.....so I replaced the motor and the cycling thermostat just for good measure. When I rechecked the temperature I found that even though the motor was running very fast with no change in speed my exhaust temp still was 167-174 and that was on all three temp settings. Since then I have put a temp selector switch,a heating element and another cycling thermostat in. No change. The voltage to the cycling therm heater are: high temp-0volts, med temp-100volts, low temp-119 volts. I know there aren't many parts left. But would really appreciate some advice. Currently have the fuse jumped out and don't want to hook it up until something changes on my temps... thanks
Related Models
Whirlpool LER7646JT0 DRYER
Whirlpool LER7648KQ0 RESIDENTIAL DRYER
Whirlpool LER7648KQ1 RESIDENTIAL DRYER
Whirlpool LER7648KQ2 RESIDENTIAL DRYER
Whirlpool LER7648KQ3 29"ELECTRIC DRYER
Whirlpool LER7648KT0 RESIDENTIAL DRYER
Whirlpool LER7648KT1 RESIDENTIAL DRYER
Whirlpool LER7648KT2 RESIDENTIAL DRYER
Whirlpool LER7648KT3 29"ELECTRIC DRYER
Whirlpool LER7648PQ0 29" ELECTRIC DRYER
Whirlpool LER7648PQ1 29" ELECTRIC DRYER
Whirlpool LER7648PT0 29" ELECTRIC DRYER
Whirlpool LER7648PT1 29" ELECTRIC DRYER
Whirlpool LER7848DQ0 ELECTRIC DRYER
Whirlpool LER7848DQ1 ELECTRIC DRYER
Whirlpool LER7848DZ0 ELECTRIC DRYER
Whirlpool LER7848DZ1 ELECTRIC DRYER
Whirlpool LER7858AN1 ELECTRIC DRYER
Whirlpool LER7858AN2 ELECTRIC DRYER
Whirlpool LER7858AW0 Residential Dryer
Whirlpool LER7858AW1 ELECTRIC DRYER
Whirlpool LER7858AW2 ELECTRIC DRYER
Whirlpool LER8620PG0 29"ELECTRIC DRYER
Whirlpool LER8620PG1 29"ELECTRIC DRYER
Whirlpool LER8620PW0 29"ELECTRIC DRYER
Whirlpool LER8620PW1 29"ELECTRIC DRYER
Whirlpool LER8648LG0 RESIDENTIAL DRYER
Whirlpool LER8648LG1 29"ELECTRIC DRYER
Whirlpool LER8648LQ0 RESIDENTIAL DRYER
Whirlpool LER8648LW0 RESIDENTIAL DRYER
Whirlpool LER8648LW1 29"ELECTRIC DRYER
Whirlpool LER8648PG0 29"ELECTRIC DRYER
Whirlpool LER8648PG1 29"ELECTRIC DRYER
Whirlpool LER8648PQ0 29" ELECTRIC DRYER
Whirlpool LER8648PQ1 29"ELECTRIC DRYER
Whirlpool LER8648PW0 29"ELECTRIC DRYER
Whirlpool LER8648PW1 29"ELECTRIC DRYER
Whirlpool LER8857EQ0 ELECTRIC DRYER
Whirlpool LER8857EQ1 DRYERS
Whirlpool LER8857EQ2 ELECTRIC DRYER
Whirlpool LER8857EZ0 ELECTRIC DRYER
Whirlpool LER8857EZ1 DRYERS
Whirlpool LER8857EZ2 ELECTRIC DRYER
Whirlpool LER8858DQ0 ELECTRIC DRYER
Whirlpool LER8858DQ1 ELECTRIC DRYER
Whirlpool LER8858DZ0 ELECTRIC DRYER
Whirlpool LER8858DZ1 ELECTRIC DRYER
Whirlpool LER8858EQ0 ELECTRIC DRYER
Whirlpool LER8858EQ1 DRYERS
Whirlpool LER8858EQ2 ELECTRIC DRYER
Whirlpool LER8858EZ0 ELECTRIC DRYER
Whirlpool LER8858EZ1 DRYERS
Whirlpool LER8858EZ2 ELECTRIC DRYER
Whirlpool LER8875EQ1 ELECTRIC DRYER
Amana LES10AW WASHER-TOP LOADING
Amana LES19AW DRYER- GAS
Amana LES33AW DRYER- GAS
Amana LES34AW WASHER-TOP LOADING
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Frigidaire LESR26EFE3 REFRIGERATOR
Frigidaire LESR26EFE4 REFRIGERATOR
Frigidaire LESR26EFE5 REFRIGERATOR
Frigidaire LESR26EFE6 REFRIGERATOR
Frigidaire LESR26EFE7 REFRIGERATOR
Whirlpool LET5434AQ0 Residential Dryer
Whirlpool LET5434AW0 Residential Dryer
Whirlpool LET5436AW0 Residential Dryer
Whirlpool LET5624BN0 ELECTRIC DRYER
Whirlpool LET5624BN1 ELECTRIC DRYER
Whirlpool LET5624BN2 ELECTRIC DRYER
Whirlpool LET5624BQ0 ELECTRIC DRYER
Whirlpool LET5624BQ1 ELECTRIC DRYER
Whirlpool LET5624BQ2 ELECTRIC DRYER
Whirlpool LET5624BW0 ELECTRIC DRYER
Whirlpool LET5624BW1 ELECTRIC DRYER
Whirlpool LET5624BW2 ELECTRIC DRYER
Whirlpool LET5624DQ0 ELECTRIC DRYER
Whirlpool LET5624DQ1 DRYER
Whirlpool LET6634AN1 ELECTRIC DRYER
Whirlpool LET6634AN2 ELECTRIC DRYER
Whirlpool LET6634AQ0 ELECTRIC DRYER
Whirlpool LET6634AQ1 ELECTRIC DRYER
Whirlpool LET6634AQ2 ELECTRIC DRYER
Whirlpool LET6634AW0 Residential Dryer
Whirlpool LET6634AW1 ELECTRIC DRYER
Whirlpool LET6634AW2 ELECTRIC DRYER
Whirlpool LET6634DQ0 ELECTRIC DRYER
Whirlpool LET6634DQ1 ELECTRIC DRYER
Whirlpool LET6634DZ0 ELECTRIC DRYER
Whirlpool LET6634DZ1 ELECTRIC DRYER
Whirlpool LET6638AN1 DRYER
Whirlpool LET6638AN2 ELECTRIC DRYER
Whirlpool LET6638AQ2 ELECTRIC DRYER
Whirlpool LET6638AW0 Residential Dryer
Whirlpool LET6638AW1 DRYER
Whirlpool LET6638AW2 ELECTRIC DRYER
Whirlpool LET6638DQ0 ELECTRIC DRYER
Whirlpool LET6638DQ1 ELECTRIC DRYER
Whirlpool LET6638DZ0 ELECTRIC DRYER
Whirlpool LET6638DZ1 ELECTRIC DRYER
Whirlpool LET7646AQ0 Residential Dryer
Whirlpool LET7646AQ1 ELECTRIC DRYER
Whirlpool LET7646AQ2 ELECTRIC DRYER
Whirlpool LET7646AW0 Residential Dryer
Whirlpool LET7646AZ1 ELECTRIC DRYER
Whirlpool LET7646AZ2 ELECTRIC DRYER
Whirlpool LET7646DQ0 ELECTRIC DRYER
Whirlpool LET7646DQ1 ELECTRIC DRYER
Whirlpool LET7646DZ0 ELECTRIC DRYER
Whirlpool LET7646DZ1 ELECTRIC DRYER
Whirlpool LET7646EQ0 ELECTRIC DRYER
Whirlpool LET7646EQ1 DRYERS
Whirlpool LET7646EQ2 ELECTRIC DRYER
Whirlpool LET7646EZ0 ELECTRIC DRYER
Whirlpool LET7646EZ1 DRYERS
Whirlpool LET7646EZ2 ELECTRIC DRYER
Whirlpool LET7848AQ0 Residential Dryer
Whirlpool LET7848AQ1 ELECTRIC DRYER
Whirlpool LET7848AQ2 ELECTRIC DRYER
  #2 (permalink)
Old 03-01-2017, 09:35 PM
Senior Member
PNWDrew is on a distinguished road
Default
The element should be cycling on and off to control the temps. The setting is the average over time and even when working well in those it might allow the temp to drop to 100 on low and 120 on high, not much difference. The peaks will be similar no matter what you select.
Also I would not consider 170F at the outlet to be very hot. That thermal fuse opens at 91 C, sustained for several minutes, about 195 deg.
By far the most common reason for thermal fuse trips is airflow out of the house. Sometimes they just fail but I change 6 or more per week for airflow issues.
I'm not sure what you mean when you say the motor slowed almost to a stop.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Brand new fridge - temp adjustment settings akstens Refrigerator & Freezer Repair 3 03-01-2013 06:17 AM
Temp settings keep changing on their own, temp too cold snakestu Refrigerator & Freezer Repair 3 04-16-2011 05:35 AM
GE Double oven - top doesn't bake, bottom temp settings don't work JerryCaldwell Oven Repair (including Ranges and Cooktops) 0 04-20-2010 04:43 PM
Refrigerator not cooling on lower temp settings acanamar Refrigerator & Freezer Repair 2 10-08-2008 06:20 AM
no heat generated in any of the 4 temp settings mikehendrix Dryer Repair 2 10-07-2008 02:01 AM
