Discuss
Kenmore Elite Oasis Dryer Squealing
 in
Dryer Repair
Hi there. Hoping someone can help narrow down the possibilities. I have a Kenmore Elite Oasis dryer, basically the same
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Elite Oasis Dryer Squealing
  #1 (permalink)
Old 02-24-2017, 06:01 PM
Junior Member
Secret Ingredient is on a distinguished road
Default Kenmore Elite Oasis Dryer Squealing
Model Number: 110.67042600   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore Elite Oasis dryer, basically the same as a whirlpool cabriolet, I believe. It recently started squealing a moment after starting, so I ordered the maintenance kit and replaced the rollers, belt and idler pulley, and cleaned it up as best I could. The felt at the front and rear of the drum was not replaced, but looked ok to me, although I really don't know exactly how it should look.
Unfortunately that did not fix it. Same loud squealing sound. The blower fan is running as it's pushing air and the drum sounds like it's turning but the squeal starts quickly and just gets worse until I turn it off. I have not let it run more than a minute or so.
So it seems it could be the felt, the blower bearing, or the motor bearings. I'm disinclined to think it's the felt as it's a fairly high pitched squeal, and does not sound like a slow speed metal against metal.
Any suggestions?
Thanks.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 02-25-2017, 10:43 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Good information, but I have a couple of questions.
Have you tried starting the dryer with with the blower belt off and running on air dry (no heat) to see if the squealing is gone?
My best guess is its either the motor or the blower bearing. Both would be high speed squealing.
I guess it could be the smaller belt slipping, but you would notice less airflow if that were true.
I don't know why Whirlpool changed to this design. They added an extra bearing, pulley and belt to a design that worked just fine for 20+ years.
  #3 (permalink)
Old 03-01-2017, 02:48 PM
Junior Member
Default
Here are some pics of the felt and the wear on the front dryer panel at the area the felt contacts it. Does this look normal? I know the pics are not great, but I don't see anywhere on the felt where it has worn through to expose metal. It seems ok to me.
Thanks,
[IMG]http://forum.appliancepartspros.com/Kenmore Oasis Dryer by sparky005s, on Flickr[/IMG]
  #4 (permalink)
Old 03-04-2017, 06:03 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Those felt seals don't look too good. Do you get dark dust on you when you touch them?
They look like they've been really, really warm. Have you checked your vent all the way to the outside?
  #5 (permalink)
Old 03-04-2017, 10:17 AM
Senior Member
thorning is on a distinguished road
Default
My guess is that the motor bearings are going bad and are squealing and will never get any better. The felt seal is not in very good shape but it usually does not squeal but rather makes a grinding noise. Motors for a dryer are fairly expensive and you should consider a new or newer one.
  #6 (permalink)
Old 03-04-2017, 04:41 PM
Junior Member
Default
Thanks for all the responses. Parts are expensive. I think we are going to let the Sun dry our clothes for a while ; )
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Oasis HE Urnhartrj88 Washer Repair 0 09-23-2012 12:38 PM
Kenmore Elite Oasis HE Dryer - Weird Rattle rpiatt Dryer Repair 0 02-01-2012 11:34 AM
Kenmore Elite Oasis kenmoresucks Washer Repair 3 08-19-2011 12:11 PM
Dryer Kenmore Elite Oasis machine640 Dryer Repair 1 05-01-2011 08:38 AM
Kenmore Elite Oasis Dryer Not Staying Powered nirvananight Dryer Repair 2 03-31-2011 09:46 AM
