Discuss
dryer timer will not advance
 in
Dryer Repair
My Kenmore dryer timer will not advance and will not shut off unless I open the door. I'm wandering if
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer timer will not advance
  #1 (permalink)
Old 02-24-2017, 05:24 PM
Junior Member
Jlb86 is on a distinguished road
Default dryer timer will not advance
Brand: Kenmore   Age: More than 10 years
My Kenmore dryer timer will not advance and will not shut off unless I open the door. I'm wandering if I can fix it or if I just need a new dryer.
  #2 (permalink)
Old 02-25-2017, 10:32 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Quote:
Your description is a little vague.
The timer will not advance in any of the cycles? Even timed dry?
Does it seem to be heating OK?
When it reaches the end of a cycle (lets say you turn the knob manually) It won't shut off and the only way to stop it is to open the door?
  #3 (permalink)
Old 02-25-2017, 11:19 AM
Junior Member
Default
No the timer will notadvance on any setting. It dries just fine. But will not shut off unless the door is opened
  #4 (permalink)
Old 02-25-2017, 12:13 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
In that case its most likely the timer. Probably has a contact welded together inside.
  #5 (permalink)
Old 02-25-2017, 12:56 PM
Junior Member
Default
Where would I find a new part? Its an '80s model
  #6 (permalink)
Old 02-25-2017, 01:38 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Can you post your model number?
  #7 (permalink)
Old 02-27-2017, 05:29 AM
Senior Member
thorning is on a distinguished road
Default
You need to put in the model number to help identify the p/n of the timer. You can usually find it on this web site Appliance Parts Pros or an alternate location is ApplianceJunk.com . Dont be suprised if you find the cost is more than $100 in which case you should consider getting a new dryer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Dryer Timer Won't Advance tmhmah4 Dryer Repair 8 03-21-2015 05:51 PM
Dryer timer will not advance Brian7780 Dryer Repair 1 11-15-2010 10:40 AM
Timer on Gas Dryer does not advance Jeff Harper Dryer Repair 0 07-08-2010 05:39 PM
Dryer timer won't advance JMBKGB Dryer Repair 0 05-01-2010 04:59 PM
Dryer Timer Will Not Advance cyclone Dryer Repair 2 01-16-2009 02:10 PM
