Discuss
WEIRD ONE: Stacked Dryer Squeaks When Washer Spins
 in
Dryer Repair
This has been going on a bit. The dryer makes zero squeak when it's running. The washer makes zero squeak
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » WEIRD ONE: Stacked Dryer Squeaks When Washer Spins
  #1 (permalink)
Old 02-21-2017, 05:24 PM
Junior Member
andythefiredog is on a distinguished road
Default WEIRD ONE: Stacked Dryer Squeaks When Washer Spins
Model Number: LG Direct drive   Brand: -other-   Age: 5 - 10 years
This has been going on a bit. The dryer makes zero squeak when it's running. The washer makes zero squeak when it's running. Everything operates fine. The dryer is stacked on the washer. I've verified a few times the stacking kit is correct and right. I've verified the washer is level. The only other thing I've been able to determine is if I pull out the stacked unit and press my hand on the lower right front corner of the dryer flexing that metal I can make is squeak the same. If I put my hand or a screw driver underneath it and press on the metal there it squeaks. It SEEMS if I hold my other hand against the bracket on the bottom front below that side that curves up into the front panel (this bracket and its left partner appears to be what the front rests on and swings down around), the squeak is lessened.
It is a VERY loud squeak when the washer is spinning.
Apologies for any typos, I'm on my phone.
Related Models
Amana LG1009W DRYER- GAS
Amana LG1101 DRYER- GAS
Amana LG1112 WASHER-TOP LOADING
Amana LG1112 DRYER- GAS
Whirlpool LG2001XSW0 Residential Dryer
Amana LG2112L DRYER- GAS
Amana LG2112W DRYER- GAS
Amana LG2401 DRYER- GAS
Amana LG2412 WASHER-TOP LOADING
Amana LG2412 DRYER- GAS
Amana LG2501 DRYER- GAS
Amana LG2512 WASHER-TOP LOADING
Amana LG2512 DRYER- GAS
Amana LG2811 DRYER- GAS
Amana LG2812 WASHER-TOP LOADING
Amana LG2812 DRYER- GAS
Amana LG2902 WASHER-TOP LOADING
Amana LG2911 DRYER- GAS
Amana LG2912 WASHER-TOP LOADING
Amana LG2912 DRYER- GAS
Whirlpool LG3001XMW0 Residential Dryer
Whirlpool LG3001XMW1 Residential Dryer
Whirlpool LG3001XMW2 Residential Dryer
Whirlpool LG3001XPW0 Residential Dryer
Whirlpool LG3001XSW0 Residential Dryer
Whirlpool LG3006XPW0 Residential Dryer
Amana LG3412G DRYER- GAS
Amana LG3412L DRYER- GAS
Amana LG3412W DRYER- GAS
Amana LG3512L DRYER- GAS
Amana LG3512W DRYER- GAS
Amana LG3812L DRYER- GAS
Amana LG3812W DRYER- GAS
Amana LG3912L DRYER- GAS
Amana LG3912W DRYER- GAS
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L DRYER- GAS
Amana LG4209L2 DRYER- GAS
Amana LG4209W DRYER- GAS
Amana LG4209W2 DRYER- GAS
Amana LG4219L2 DRYER- GAS
Amana LG4219W2 DRYER- GAS
Amana LG4309L DRYER- GAS
Amana LG4309W DRYER- GAS
Amana LG4319L2 DRYER- GAS
Amana LG4319W2 DRYER- GAS
Amana LG4409L DRYER- GAS
Amana LG4409W DRYER- GAS
Amana LG4429L DRYER- GAS
Amana LG4429W DRYER- GAS
Whirlpool LG4441XWW0 Residential Dryer
Whirlpool LG4441XWW1 Residential Dryer
Amana LG4509L DRYER- GAS
Amana LG4509W DRYER- GAS
Amana LG4609L DRYER- GAS
Amana LG4609W DRYER- GAS
Amana LG4809L DRYER- GAS
Amana LG4809W DRYER- GAS
Amana LG4909L DRYER- GAS
Amana LG4909W DRYER- GAS
Whirlpool LG4931XMW0 Residential Dryer
Whirlpool LG4931XSW0 Residential Dryer
Whirlpool LG4931XTW0 Residential Dryer
Whirlpool LG4931XTW1 Residential Dryer
Whirlpool LG4931XTW2 Residential Dryer
Whirlpool LG4936XMW0 Residential Dryer
Whirlpool LG4936XMW1 Residential Dryer
Whirlpool LG5201XTW0 Residential Dryer
Whirlpool LG5201XTW1 Residential Dryer
Whirlpool LG5321XTW0 Residential Dryer
Whirlpool LG5531XKW0 Residential Dryer
Whirlpool LG5531XKW1 Residential Dryer
Whirlpool LG5531XMG2 GAS DRYER
Whirlpool LG5531XMN2 GAS DRYER
Whirlpool LG5531XMW0 Residential Dryer
Whirlpool LG5531XMW1 Residential Dryer
Whirlpool LG5531XMW2 GAS DRYER
Whirlpool LG5531XPW0 Residential Dryer
Whirlpool LG5531XSW0 Residential Dryer
Whirlpool LG5531XSW1 Residential Dryer
Whirlpool LG5536XPW0 Residential Dryer
Whirlpool LG5551XTG0 GAS DRYER
Whirlpool LG5551XTN0 GAS DRYER
Whirlpool LG5551XTW0 Residential Dryer
Whirlpool LG5601XMW0 Residential Dryer
Whirlpool LG5601XPW0 Residential Dryer
Whirlpool LG5601XSW0 Residential Dryer
Whirlpool LG5601XSW1 Residential Dryer
Whirlpool LG5606XPW0 Residential Dryer
Whirlpool LG5651XKW0 Residential Dryer
Whirlpool LG5651XKW1 Residential Dryer
Whirlpool LG5651XMW0 Residential Dryer
Whirlpool LG5651XMW1 Residential Dryer
Whirlpool LG5701XKW0 Residential Dryer
Whirlpool LG5701XMW0 Residential Dryer
Whirlpool LG5701XMW1 Residential Dryer
Whirlpool LG5701XMW2 Residential Dryer
Whirlpool LG5701XPW0 Residential Dryer
Whirlpool LG5701XSN0 GAS DRYER
Whirlpool LG5701XSW0 Residential Dryer
Whirlpool LG5706XPW0 Residential Dryer
Whirlpool LG5721XPW0 Residential Dryer
Whirlpool LG5721XSW0 Residential Dryer
Whirlpool LG5721XSW1 Residential Dryer
Whirlpool LG5726XPW0 Residential Dryer
Whirlpool LG5751XFW0 Residential Dryer
Whirlpool LG5751XKW0 Residential Dryer
Whirlpool LG5751XKW1 Residential Dryer
Whirlpool LG5751XMW0 Residential Dryer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
stacked washer,dryer jim riz Washer Repair 0 02-03-2014 07:59 PM
Stacked washer and dryer lonesomepolecat Dryer Repair 0 10-24-2012 02:31 PM
Stacked washer dryer jjarps Washer Repair 1 01-30-2012 06:49 PM
Stacked washer and dryer acting very weird timbergeek Dryer Repair 1 05-21-2009 03:40 PM
stacked washer dryer housewife Washer Repair 0 06-05-2008 09:11 AM
