Discuss
Troubleshooting Help: Heats at first, then just cold air..?
 in
Dryer Repair
I have a Samsung Steam Dryer (Gas) Model DV338AGW • No obstructions in the duct • We start a load
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Troubleshooting Help: Heats at first, then just cold air..?
  #1 (permalink)
Old 02-16-2017, 01:56 PM
Junior Member
KatieWisc is on a distinguished road
Default Troubleshooting Help: Heats at first, then just cold air..?
Brand: Samsung   Age: Less than 1 year
Model DV338AGW
• We start a load of wet laundry and choose any heat setting. Starts fine, hear the fire ignite.
• At some point in the cycle, we discover that the heat has stopped and the load is, now, essentially air drying. We try to start the load again. After pressing Start, the dryer begins to turn as usual.... but, about 15 seconds in, we hear a click click click click click and at the same time, there is an orange glow (below the drum, left side).... the clicking stops and the dryer continues to air dry without heat.
• At this point, if we try an air only setting, we do not hear the clicking.
• If we let the dryer sit for a long period of time (more than an hour) and we attempt drying again with heat, it does start up normally (we hear the blower ignite) and it does create heat. But again, it stops heating at some point in the cycle.
Some history on the machine - we did get this machine used. It is in great condition otherwise. The first load we tried in this machine dried perfectly.
Any ideas what would cause the heat to stop blowing midway through? I cannot find anything on Google. Thank you!
  #2 (permalink)
Old 02-17-2017, 08:11 PM
Senior Member
PNWDrew is on a distinguished road
Default
This is a gas dryer? If so it sounds like your coils in the gas valve have failed or are failing. As they fail they will often open the valve the first few times and then become unreliable.
Once you get your model # I'll be able to tell you how to replace, I'm not sure if the coils come separately on Samsung.
  #3 (permalink)
Old 03-26-2017, 06:44 PM
Junior Member
Default
Yes, this is a gas dryer.
Model # is Samsung DV338AGW.
We have now tried replacing the thermistor and the thermal fuse, but still no luck. It's driving us crazy.
Thank you for any help you can provide!
  #4 (permalink)
Old 03-27-2017, 02:20 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
PNWDrew is probably right. Its most likely the gas valve coils. What happens is this, one of the coils gets a hairline crack in its winding. When its cold it functions and opens the gas valve, When the coil winding gets hot it opens and no more gas till it cools back down. Eventually it will just fail all together.
This is the parts diagram.
Parts for Samsung DV338AGW/XAA-0000 / : Heater Assy Parts - AppliancePartsPros.com
Its part of 3-4 assembly
Samsung DC62-00201A Valve - AppliancePartsPros.com
I can't see why these wouldn't work. Most appliance manufacturers make separate coils you can replace, why Samsung doesn't list them is beyond me.
Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
  #5 (permalink)
Old 03-30-2017, 06:40 PM
Junior Member
Default
To the user THAT GUY:
THANK YOU for your input and advice because it worked!! I am on my third load of laundry and it's pumping heat consistently. Thank you thank you thank you!
For others:
The part I purchased for my DV388AGW Samsung Steam dryer:
"AP3094251 GAS DRYER COILS FOR MAYTAG AMANA ROPER ESTATE WHIRLPOOL KENMORE
Purchased on ******** for $7 + free shipping. This part # apparently fits on many makes/models.Comes with two little black/white cylinders. Very easy to replace. When taking off the old ones, don't forget to keep the little metal spacer (on the bigger, 3-prong one) because the replacements will not come with one.In all, I spent ~$24 on a thermistor and thermal fuse (didn't fix the issue) and another $7 on the gas valve coils.
$31 to fix the dryer - could not be happier!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drying heats up when off but when running it's cold Taylorj3991 Dryer Repair 1 07-08-2016 07:05 AM
freezer cool, refrig cold, basic troubleshooting complete lightfall Refrigerator & Freezer Repair 0 08-16-2014 04:48 PM
Dryer heats for 2 minutes then gets cold TeeTheWorld Dryer Repair 2 04-19-2012 10:59 AM
Dryer heats then goes cold K Casper Dryer Repair 0 02-23-2012 07:35 AM
gas dryer heats up then gets cold Waterdog1717 Dryer Repair 0 09-30-2011 07:21 PM
