Discuss
Dryer Not Stopping or Heating
 in
Dryer Repair
I have a Kenmore 70s series dryer. It recently quit heating in addition to continually running even though the timer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Not Stopping or Heating
  #1 (permalink)
Old 02-07-2017, 11:45 AM
Junior Member
JordanS81 is on a distinguished road
Default Dryer Not Stopping or Heating
Brand: Kenmore   Age: More than 10 years
I have a Kenmore 70s series dryer. It recently quit heating in addition to continually running even though the timer passed the "Off" section of timed dry. I'm assuming the issues are related. Any suggestions?
The model number is 110.66742501.
  #2 (permalink)
Old 02-12-2017, 01:26 PM
Senior Member
PNWDrew is on a distinguished road
Default
From your description I'd guess it's the timer. However sometimes a failed element will short to ground in a way that powers the timer motor continually. Usually that produces some heat however.
Run it on air dry, is there any heat at all? If not it's probably the timer. If you get it here you should be able to return it if it proves to not be the solution. It's a very easy fix. a few screws and you're done
Whirlpool WP8299784 Timer - AppliancePartsPros.com
How are you stopping it now? Does the timer have any position that stops the motor? Even if you turn the knob by hand slowly?
  #3 (permalink)
Old 02-16-2017, 06:40 PM
Junior Member
Default
Thanks. I've replaced the time, but that didn't work. I also checked the voltage to the dryer and from the wall socket, but everything seems to be okay there. I did notice that the heating element might not be pulling any power, but would that have anything to do with the dryer not stopping?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Electric Dryer not stopping and not heating rschunk Dryer Repair 1 01-24-2014 09:32 AM
Dryer was stopping mid cycle now not heating up jj3900 Dryer Repair 1 02-02-2013 05:31 AM
Condenser not stopping. Evaporator fan no stopping nsamdani Refrigerator & Freezer Repair 2 08-27-2012 09:20 PM
Dryer not stopping jtowntbo5@yahoo.com Dryer Repair 1 09-18-2009 06:03 AM
Dryer keeps stopping jhips Dryer Repair 0 02-16-2009 05:50 PM
