Discuss
E71 Outlet Control Thermistor
 in
Dryer Repair
Receiving error code E71, outlet control thermistor or wiring defective. Have checked thermistor, was in range at 5.66K Ohm (between
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » E71 Outlet Control Thermistor
  #1 (permalink)
Old 02-02-2017, 12:24 PM
Junior Member
NaliKawi is on a distinguished road
Default E71 Outlet Control Thermistor
Model Number: EIED55HIW0   Brand: Electrolux   Age: 1 - 5 years
Receiving error code E71, outlet control thermistor or wiring defective. Have checked thermistor, was in range at 5.66K Ohm (between 4.9K Ohm and 6.2K Ohm), checked wire leading from thermistor to control board, read 5.66K Ohm. Checked continuity of wire (disconnected from thermistor and control board), no resistance found in each individual wire, and infinite resistance found between the two wires. Replaced thermistor and control board with no change. Inspected outlet control thermistor wires, found no kinks, breaks, etc. Reset error code after each attempted repair. Dryer will run for a few seconds, then shut off with error code E71. Tech manual describes checking for open circuit - if that is something other than checking for continuity, I don't know that that is. Help me Obi-Wan Kenobi, you're my only hope...
Related Models
 EIED55HIW0 GAS DRYER
 EIED55HMB0 GAS DRYER
 EIED55IKG0 ELECTRIC DRYER
 EIED55IRR0 ELECTRIC DRYER
 EIED5CHIW0 DRYER
 EIED5CHMB0 DRYER
 EIFLS55IIW0 WASHER
 EIFLS55IMB0 WASHER
 EIFLS55IRR0 WASHER
 EIFLS60JIW0 WASHER
 EIFLS60JMB0 WASHER
 EIFLS60JRR0 WASHER
 EIFLW55HIW0 WASHER
 EIFLW55HMB0 WASHER
 EIFLW55IKG0 WASHER
 EIFLW55IRR0 WASHER
 EIGD55HIW0 GAS DRYER
 EIGD55HIW1 GAS DRYER
 EIGD55HIW2 GAS DRYER
 EIGD55HMB0 GAS DRYER
 EIGD55HMB2 GAS DRYER
 EIGD55IKG0 GAS DRYER
 EIGD55IKG1 GAS DRYER
 EIGD55IKG2 GAS DRYER
 EIGD55IRR0 GAS DRYER
 EIGD55IRR1 GAS DRYER
 EIGD55IRR2 GAS DRYER
Thermador EIICV30 COOKTOP
Thermador EIIGG30 COOKTOPS
Thermador EIIGG36 COOKTOPS
Thermador EIIGGCV30 COOKTOPS
Thermador EIIGGCV36 COOKTOPS
Thermador EIIWD24 WARMING DRAWER
 EILFU17GS0 FREEZER
 EILFU17GS1 FREEZER
 EILFU17GS2 FREEZER
 EILFU21GS0 FREEZER
 EILFU21GS2 FREEZER
Amana EIM5-H MISC / ACCESSORY
 EIMED55IIW0 ELECTRIC DRYER
 EIMED55IMB0 ELECTRIC DRYER
 EIMED55IRR0 ELECTRIC DRYER
 EIMED60JIW0 DRYER
 EIMED60JMB0 DRYER
 EIMED60JRR0 DRYER
 EIMGD55IIW2 DRYER
 EIMGD55IMB2 DRYER
 EIMGD55IRR2 DRYER
 EIMGD60JIW0 DRYER
 EIMGD60JMB0 DRYER
 EIMGD60JRR0 DRYER
Amana EJA214 RANGE- S/C S/I DDRAFT GAS
Amana EJA312 RANGE- S/C S/I DDRAFT GAS
Amana EJA314 RANGE- S/C S/I DDRAFT GAS
Amana EJA315 RANGE- S/C S/I DDRAFT ELE
Amana EJA335 RANGE- S/C S/I DDRAFT ELE
Amana EJA367 RANGE- S/C S/I DDRAFT GAS
Amana EJA394 RANGE- S/C S/I DDRAFT GAS
Amana EJA395 RANGE- S/C S/I DDRAFT ELE
Amana EJA397 RANGE- S/C S/I DDRAFT GAS
Amana EJC312 RANGE- S/C S/I DDRAFT GAS
Amana EJC314 RANGE- S/C S/I DDRAFT GAS
Amana EJC335 RANGE- S/C S/I DDRAFT ELE
Amana EJC394 RANGE- S/C S/I DDRAFT ELE
Amana EJD335 RANGE - ELECTRIC STD DELAWARE
Amana EJD344 RANGE- S/C S/I DDRAFT GAS
Amana EJD345 RANGE- S/C S/I DDRAFT GAS
Amana EJD346 RANGE- STD MWAVE ELE
Amana EJD395 RANGE - ELECTRIC STD DELAWARE
Amana EJN3892W,L RANGE- S/C S/I DDRAFT GAS
Amana EJR304-2F/N RANGE- S/C S/I DDRAFT GAS
Amana EJS306 RANGE - ELECTRIC STD DELAWARE
Amana EJS335 RANGE - ELECTRIC STD DELAWARE
Amana EJT-346 RANGE- S/C S/I DDRAFT GAS
Whirlpool EJT142XKWR0 Refrigerators*
Whirlpool EJT144XKWR0 Refrigerators*
Whirlpool EJT161XKWR1 Refrigerators*
Whirlpool EJT161XKWR2 Refrigerators*
Whirlpool EJT181XKWR2 Refrigerators*
Amana EJT334 RANGE - ELECTRIC STD DELAWARE
Amana EKD289 WALLOVEN- STD MWAVE ELE
Amana EKD395 WALLOVEN- STD MWAVE ELE
Hardwick EKD9-51A439 RANGE- F/S STD ELE
Hardwick EKD9-51W439 RANGE- F/S STD ELE
Hardwick EKD9-52A439 RANGE- F/S CONT CLEAN ELE
Hardwick EKD9-52W439 RANGE- F/S CONT CLEAN ELE
 EKDR14XAKW0 DRYER
Hardwick EKF9-71A-569W ELECTRIC RANGE
Hardwick EKF9-71W-569W ELECTRIC RANGE
Hardwick EKG971A549 RANGE- F/S STD ELE
Hardwick EKG971W549 RANGE- F/S STD ELE
Amana EKS289 WALLOVEN- STD MWAVE ELE
Amana EKS395 WALLOVEN- STD MWAVE ELE
Amana EKS396 WALLOVEN- STD MWAVE ELE
Amana EKT-396 RANGE- S/C S/I DDRAFT GAS
Whirlpool EL02CCXHW00 COMPACT REFRIGERATOR
Whirlpool EL02CCXHW1 COMPACT REFRIGERATOR
Whirlpool EL02CCXJW COMPACT REFRIGERATOR
Whirlpool EL02CCXLB
Whirlpool EL02CCXMB00 REFRIGERATOR
Whirlpool EL02CCXMQ00 REFRIGERATOR
Whirlpool EL02CCXPB00 COMPACT REFRIGERATOR
Whirlpool EL02CCXPQ00 COMPACT REFRIGERATOR
Whirlpool EL02CCXWW0 Refrigerators*
Whirlpool EL02PPXMB00 REFRIGERATOR
Whirlpool EL02PPXMQ00 REFRIGERATOR
Whirlpool EL03CCXDW00 REFRIGERATOR
Whirlpool EL03CCXFW00 COMPACT REFRIGERATOR
Whirlpool EL03CCXHW00 COMPACT REFRIGERATOR
Whirlpool EL03CCXJW COMPACT REFRIGERATOR
Whirlpool EL03CCXLB
Whirlpool EL03CCXMB00 REFRIGERATOR
Whirlpool EL03CCXMQ00 REFRIGERATOR
Whirlpool EL03CCXMS00 REFRIGERATOR
Whirlpool EL03CCXRB00 REFRIGERATOR
Whirlpool EL03CCXRQ00 REFRIGERATOR
Whirlpool EL03CCXWW0 Refrigerators*
Whirlpool EL03PPXMB00 REFRIGERATOR
Whirlpool EL03PPXML00 REFRIGERATOR
  #2 (permalink)
Old 02-06-2017, 12:18 PM
Junior Member
Default
I have since gone so far as to remove the cover for the control board and check the reading on the board itself - it also reads 5.66K Ohms, so now I'm really at a loss to explain the problem. Still looking for help here...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
control board or thermistor problem/ wiring diagram available? novice2397 Refrigerator & Freezer Repair 0 08-10-2012 08:28 AM
Dryer control panel not lighting now...replaced thermistor and fuse Stacey62 Dryer Repair 0 08-07-2011 06:42 PM
Control Electronics Board & Thermistor Replaced - No Go drexanth Dryer Repair 1 03-22-2010 05:53 PM
new thermistor JPNLJ Dryer Repair 1 02-13-2009 08:27 PM
