Register | FAQ's | New Posts | Today's Posts | Extras |
» squeaking like mad |
![]() Model Number: GLGH1642FS1 Brand: Frigidaire Age: 5 - 10 years
![]() I have a dryer thats squeaking like crazy. Repair tech says it needs some felt pads and a bushing. Parts $80ish, total repair $500ish. Its a front loader, if I push up on the front of the basket - it moves almost 1/4 inch. Something is certainly worn. I think I'll try it myself if I can get some info. Otherwise, time for a new one. Can anyone help with what parts it might be? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() #23 and 24 on this diagram are your front felt slides, that'll fix the movement you feel. At a minimum do the upper felt, it's the most worn.
Parts for Frigidaire GLGH1642FS1: Upper Cabinet / Drum Heater Parts - AppliancePartsPros.com Squeaking is probably the rear bearing. Might be the pulley that keeps the belt tight but probably the bearing. Frigidaire 5303281153 Rear Drum Bearing Kit - AppliancePartsPros.com Doing it yourself is an ambitious project unless you're pretty handy by nature. You should be quite proud if you do it successfully. Neither is a very hard repair, however being a laundry center adds some difficulty getting it apart. Post back if you decide to do it and I'll walk you through as best as I can. There are excellent videos here at the part links for many things. Your laundry center is similar to the stand alone dryer the video shows. Last edited by PNWDrew : 02-03-2017 at 06:52 PM. |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
squeaking dryer | mecnc | Dryer Repair | 0 | 09-09-2011 11:56 AM |
GE Gas Dryer Squeaking | myeags | Dryer Repair | 0 | 05-06-2010 07:47 PM |
Squeaking | nhgator | Dryer Repair | 1 | 02-16-2010 06:15 PM |
squeaking like a sob | greg123 | Dryer Repair | 1 | 12-31-2009 03:59 PM |
squeaking dryer | medic3019 | Dryer Repair | 3 | 03-02-2009 07:19 AM |
