mnovara
#1 Posted : Thursday, February 21, 2008 8:30:12 AM(UTC)
mnovara
My kenmore dryer will start and run for about 5 minutes then quit. After a couple of minutes, we can start it again but the same thing happens. Any suggestions?
kooler
#2 Posted : Thursday, February 21, 2008 4:04:26 PM(UTC)
kooler
Check wiring connections at the door switch... A loose wiring connection or faulty switch could be giving the indication to the circuit that the door is being opened and turning off the dryer when in reality it's not...
#3 Posted : Thursday, February 21, 2008 4:50:54 PM(UTC)
Also cause of such problem could be a clogged exhaust (outside of the dryer as well as inside) leading to overheating or a faulty thermistor (if any).
In order to provide the most accurate advise we need the complete model number of the dryer.
Dryer won't keep running (Dryer Repair)
by thomwes2 11/18/2009 8:00:11 AM(UTC)
dryer won't keep running, overheats (Dryer Repair)
by readdream 9/21/2009 10:21:15 AM(UTC)
Kenmore Elite Dryer won't keep running (Dryer Repair)
by user22 9/11/2009 12:22:37 PM(UTC)
Kenmore dryer won't keep running after release button (Dryer Repair)
by cd195 5/2/2008 2:46:43 PM(UTC)
