Discuss
Dryer won't stay on
 in
Dryer Repair
Dryer intermittently will not stay on. When I press and hold the start button, the drum turns, heat comes on,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't stay on
  #1 (permalink)
Old 01-31-2017, 07:30 PM
Junior Member
steve615 is on a distinguished road
Default Dryer won't stay on
Brand: Kenmore   Age: 5 - 10 years
When I press and hold the start button, the drum turns, heat comes on, and as far as I can tell the dryer is operating normally. However, when I release the start button, it immediately stops (Drum stops, heat stops as if the cycle was done). After some experimenting, I found that I could spin the timer knob several times (counterclockwise and clockwise) and after awhile I could press the start button (and release) and the dryer would stay on and function as normal (Complete a normal length cycle, appropriately dry, clothes came out feeling warm like usual). So for the past few months I've used my "spin the timer knob" trick to get my laundry done. However, this week it stopped working and dryer won't stay on. To attempt a repair, I replaced the timer motor with an appropriate replacement part. After replacement, the dryer seemed fixed for 2-3 loads. However, the same problem returned less than 24 hour after replacing the timer motor.
Any help is appreciated.
  #2 (permalink)
Old 02-03-2017, 06:55 PM
Senior Member
PNWDrew is on a distinguished road
Default
Model #? It's probably inside the door. There are some easy possibilities but we'd need your model # to help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Won't Stay On..If you hold the start button dryer runs fine nickbert Dryer Repair 3 02-28-2012 03:59 PM
GE Dryer does not stay on t.coblentz Dryer Repair 0 11-16-2011 05:51 PM
Kenmore Washer/Dryer Combo Dryer won't stay on Jmasters Dryer Repair 0 09-06-2011 10:49 AM
Dryer will not stay hot JAN0 Dryer Repair 1 03-08-2011 10:08 AM
Dryer Will Not Stay Hot michaelhall Dryer Repair 0 04-06-2010 03:27 PM
