Discuss
gas dryer with intermittent heat
 in
Dryer Repair
This is a Kenmore series 70 gas dryer. During the initial start everything functions normally. Flames up and runs for
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas dryer with intermittent heat
  #1 (permalink)
Old 01-21-2017, 01:14 PM
Junior Member
highpoint is on a distinguished road
Question gas dryer with intermittent heat
Model Number: 11076722695   Brand: Kenmore   Age: More than 10 years
This is a Kenmore series 70 gas dryer. During the initial start everything functions normally. Flames up and runs for 5-7 min then cycles down, when it tries to re-ignite on the next heat cycle you can here a chattering sound, the ignitor glows but no gas is released to light, then the ignitor cycles back down. Here are the components I have replaced, gas coils, ignitor, flame sensor, cycling thermostat. The timer, thermal fuse, and hi-temp thermostat were checked with a multi-meter and all checked out. I think the only thing left is the gas valve itself, but given that it works initially AND some repair guys and my local parts supplier says that would be VERY unlikely( and costly). Anybody got two more cents to put in?
Related Models
Kenmore 11076722695 GAS DRYER
Kenmore 11076732500 RESIDENTIAL DRYER
Kenmore 11076732501 RESIDENTIAL DRYER
Kenmore 11076742500 RESIDENTIAL DRYER
Kenmore 11076742501 RESIDENTIAL DRYER
Kenmore 11076752500 DRYER
Kenmore 11076752501 RESIDENTIAL DRYER
Kenmore 11076774100 KENMORE ELECTRIC DRYER
Kenmore 11076774200 KENMORE ELECTRIC DRYER
Kenmore 11076774400 KENMORE ELECTRIC DRYER
Kenmore 11076774600 KENMORE ELECTRIC DRYER
Kenmore 11076784100 KENMORE ELECTRIC DRYER
Kenmore 11076784200 KENMORE ELECTRIC DRYER
Kenmore 11076784400 KENMORE ELECTRIC DRYER
Kenmore 11076784600 KENMORE ELECTRIC DRYER
Kenmore 11076785100 KENMORE ELECTRIC DRYER
Kenmore 11076785200 KENMORE ELECTRIC DRYER
Kenmore 11076785400 KENMORE ELECTRIC DRYER
Kenmore 11076785600 KENMORE ELECTRIC DRYER
Kenmore 11076801690 ELECTRIC DRYER
Kenmore 11076801691 GAS DRYER
Kenmore 11076801692 GAS DRYER
Kenmore 11076801693 GAS DRYER
Kenmore 11076801694 GAS DRYER
Kenmore 11076801695 GAS DRYER
Kenmore 11076808690 GAS DRYER
Kenmore 11076808691 GAS DRYER
Kenmore 11076808692 GAS DRYER
Kenmore 11076808693 GAS DRYER
Kenmore 11076808694 GAS DRYER
Kenmore 11076808695 GAS DRYER
Kenmore 11076812690 ELECTRIC DRYER
Kenmore 11076812691 GAS DRYER
Kenmore 11076812692 GAS DRYER
Kenmore 11076812693 GAS DRYER
Kenmore 11076812694 GAS DRYER
Kenmore 11076812695 GAS DRYER
Kenmore 11076814690 GAS DRYER
Kenmore 11076814691 GAS DRYER
Kenmore 11076814692 GAS DRYER
Kenmore 11076814693 GAS DRYER
Kenmore 11076814694 GAS DRYER
Kenmore 11076814695 GAS DRYER
Kenmore 11076822690 SUPER CAPACITY PLUS CLOTHES DRYER
Kenmore 11076822691 GAS DRYER
Kenmore 11076822692 GAS DRYER
Kenmore 11076822693 Residential Dryer
Kenmore 11076822694 GAS DRYER
Kenmore 11076822695 GAS DRYER
Kenmore 11076824690 GAS DRYER
Kenmore 11076824691 GAS DRYER
Kenmore 11076824692 GAS DRYER
Kenmore 11076824693 GAS DRYER
Kenmore 11076824694 GAS DRYER
Kenmore 11076824695 GAS DRYER
Kenmore 11076832500 RESIDENTIAL DRYER
Kenmore 11076832501 RESIDENTIAL DRYER
Kenmore 11076842500 DRYER
Kenmore 11076842501 RESIDENTIAL DRYER
Kenmore 11076852690 ELECTRIC DRYER
Kenmore 11076852691 GAS DRYER
Kenmore 11076852692 GAS DRYER
Kenmore 11076852693 Residential Dryer
Kenmore 11076852694 GAS DRYER
Kenmore 11076852695 GAS DRYER
Kenmore 11076854690 GAS DRYER
Kenmore 11076854691 GAS DRYER
Kenmore 11076854692 GAS DRYER
Kenmore 11076854693 GAS DRYER
Kenmore 11076854694 GAS DRYER
Kenmore 11076854695 GAS DRYER
Kenmore 11076860100 KENMORE ELECTRIC DRYER
Kenmore 11076860200 KENMORE ELECTRIC DRYER
Kenmore 11076860400 KENMORE ELECTRIC DRYER
Kenmore 11076860600 KENMORE ELECTRIC DRYER
Kenmore 11076860800 KENMORE ELECTRIC DRYER
Kenmore 11076862500 RESIDENTIAL DRYER
Kenmore 11076862501 RESIDENTIAL DRYER
Kenmore 11076864501 RESIDENTIAL DRYER
Kenmore 11076870100 KENMORE ELECTRIC DRYER
Kenmore 11076870200 KENMORE ELECTRIC DRYER
Kenmore 11076870400 KENMORE ELECTRIC DRYER
Kenmore 11076870600 KENMORE ELECTRIC DRYER
Kenmore 11076870800 KENMORE ELECTRIC DRYER
Kenmore 11076872500 DRYER
Kenmore 11076872501 RESIDENTIAL DRYER
Kenmore 11076873100 KENMORE ELECTRIC DRYER
Kenmore 11076873200 KENMORE ELECTRIC DRYER
Kenmore 11076873400 KENMORE ELECTRIC DRYER
Kenmore 11076873600 KENMORE ELECTRIC DRYER
Kenmore 11076873800 KENMORE ELECTRIC DRYER
Kenmore 11076875100 KENMORE ELECTRIC DRYER
Kenmore 11076875200 KENMORE ELECTRIC DRYER
Kenmore 11076875400 KENMORE ELECTRIC DRYER
Kenmore 11076875600 KENMORE ELECTRIC DRYER
Kenmore 11076876100 KENMORE ELECTRIC DRYER
Kenmore 11076876200 KENMORE ELECTRIC DRYER
Kenmore 11076876400 KENMORE ELECTRIC DRYER
Kenmore 11076876600 KENMORE ELECTRIC DRYER
Kenmore 11076876800 KENMORE ELECTRIC DRYER
Kenmore 11076877100 KENMORE ELECTRIC DRYER
Kenmore 11076877200 KENMORE ELECTRIC DRYER
Kenmore 11076877400 KENMORE ELECTRIC DRYER
Kenmore 11076877600 KENMORE ELECTRIC DRYER
Kenmore 11076877800 KENMORE ELECTRIC DRYER
Kenmore 11076880100 KENMORE ELECTRIC DRYER
Kenmore 11076880200 KENMORE ELECTRIC DRYER
Kenmore 11076880400 KENMORE ELECTRIC DRYER
Kenmore 11076880600 KENMORE ELECTRIC DRYER
Kenmore 11076880800 KENMORE ELECTRIC DRYER
Kenmore 11076884100 KENMORE ELECTRIC DRYER
Kenmore 11076884200 KENMORE ELECTRIC DRYER
Kenmore 11076884400 KENMORE ELECTRIC DRYER
Kenmore 11076884600 KENMORE ELECTRIC DRYER
Kenmore 11076884800 KENMORE ELECTRIC DRYER
Kenmore 11076885100 KENMORE ELECTRIC DRYER
Kenmore 11076885200 KENMORE ELECTRIC DRYER
Kenmore 11076885400 KENMORE ELECTRIC DRYER
Kenmore 11076885600 KENMORE ELECTRIC DRYER
Kenmore 11076886100 KENMORE ELECTRID DRYER
  #2 (permalink)
Old 01-21-2017, 01:52 PM
Senior Member
thorning is on a distinguished road
Default
Unfortunately it appears to be a gas valve problem. If you can return the parts you have already installed you may be able to afford to replace the valve. Otherwise you are going to have to buy a replacement dryer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer Intermittent Heat FranDaMan Dryer Repair 1 07-05-2013 05:29 AM
Gas dryer - intermittent heat JimBilly Dryer Repair 0 05-10-2013 10:14 AM
dryer intermittent no heat rpop7723 Dryer Repair 0 02-11-2012 12:03 PM
Intermittent heat in dryer katesami Dryer Repair 1 08-07-2011 08:31 AM
Dryer intermittent to no heat edm812 Dryer Repair 6 07-30-2009 07:03 PM
