The dryer will stop mid cycle, sometimes twenty minutes sometimes twenty seconds. Both with or without articles in the drum. It will restart once the PTS button is pushed. It does it on all heat/no heat setting and timer settings. In reviewing the wiring diagram, it would appear the only components of concern in the motor start/run would be the timer, push to start, door switch and of course the motor. I am going to bypass (jumper) the push to start switch and door switch one at a time to check operation of each component to try and prove there functionality. Any suggestions or recommendations would be greatly appreciated. Also the cabinet interior, motor heater and ductwork have all been completely cleaned. Thanks for any and all input.
