Discuss
Whirlpool Roper dryer timer
 in
Dryer Repair
I have already replaced the timer once in my dryer, and that fixed the problem, but has anyone heard of
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Roper dryer timer
  #1 (permalink)
Old 01-02-2017, 10:15 AM
Junior Member
kparker1028 is on a distinguished road
Default Whirlpool Roper dryer timer
Brand: Whirlpool   Age: 1 - 5 years
I have already replaced the timer once in my dryer, and that fixed the problem, but has anyone heard of a timer that will stop halfway through a cycle, but then a week later it will work again? I bought another timer to put in, but a week later before I've even gotten my timer in the mail, the dryer is back to working normally.. has this happened to anyone else?
  #2 (permalink)
Old 01-02-2017, 10:19 AM
Junior Member
Default
test reply
  #3 (permalink)
Old 01-03-2017, 07:11 PM
Junior Member
colbey is on a distinguished road
Default follow-up questions
when did you replace the timer? and why? was it a new timer that you put in before?
do you mean that the timer stopped, and so the cycle didn't complete? but now, a cycle will complete? are the clothes dry then?
  #4 (permalink)
Old 01-04-2017, 04:08 PM
Junior Member
Default
I replaced the timer the first time about 6 months ago. started having the same issue a couple weeks ago, so ordered another timer, but then the cycles started working again before I put the new timer in. The first timer was replaced because the cycle would stop halfway through and clothes would not be dry. the dryer was still getting heat, just shutting off before the cycle was complete. the new timer fixed it. It started doing it again a couple weeks ago, not completing a cycle, so ordered another timer, but then started working again on all cycles before I changed the timer again.
  #5 (permalink)
Old 01-04-2017, 07:55 PM
Junior Member
Default
so questions might be:
1- why a new timer, apparently, began having problems in only 6 months.
2- if there's a short somewhere that could be causing either the problem with cycles not completing, or a problem with the timer causing the cycles to not complete. or both.
3- if such a short exists, how/why it's intermittent, and where is it/how to fix it.
is the dryer stable? meaning, it's not bumping or thumping around so that things could be jarred loose?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool (Roper) electric dryer runs and heats. Timer does not advance in auto or ti biomed172 Dryer Repair 1 10-11-2014 05:30 AM
roper dryer timer won't advance jwb1977 Dryer Repair 1 07-10-2014 06:27 PM
roper dryer timer frankmc871@msn.com Dryer Repair 8 07-03-2011 02:55 PM
roper dryer timer frankmc871@msn.com Dryer Repair 0 06-30-2011 04:40 PM
Roper Dryer Timer Working But Nothing ELSE fixit318 Dryer Repair 4 11-20-2008 11:29 PM
