| » Dryer Displays "PF" |
Model Number: LEQ7000EG0 Brand: Electrolux Age: 1 - 5 years
I am trying to trouble shoot what "PF" means on dryer.
It will "Fluff", however it will shut off and display "PF" when heat is applied. Related Models |
Replacement parts for FRG LEQ7000EG0 | AppliancePartsPros.com Here is the tech sheet which should help you trouble shoot it http://manuals.frigidaire.com/prodin...0ts_wd_EFS.pdf Run the error code check, see the tech sheet Flip your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Better yet measure it with a meter L1 to L1 should be 240 volts L1 to Neutral and L2 to Neutral both should be 120 volts.
__________________
Did you run it a couple times and get consistent results.
On problem with on board diagnostics is if the processor goes squirrelly, then so do the diagnostics. So one indication that a board is bad is if the diagnostics give random results.
__________________
| Display Modes | |
| micro displays "DOOR", wont start | kicknbutt | Microwave Repair | 0 | 06-18-2009 02:38 PM |
| Works on "rinse only" but stops on "wash". | Bill E | Dishwasher Repair | 5 | 05-27-2009 04:00 AM |
| kenmore ELECTRIC RANGE displays "PF" | blazingsaddleman | Oven Repair (including Ranges and Cooktops) | 3 | 09-26-2008 01:16 PM |
| Amana convection oven displays "OFF" | khooker | Oven Repair (including Ranges and Cooktops) | 0 | 06-02-2008 03:41 PM |
| Oven oesn't bake/heat and displays a "FS" error message | jnymdnyt | Oven Repair (including Ranges and Cooktops) | 5 | 08-06-2007 07:36 PM |
