Discuss
Whirlpool Dryer - Timer Won't Advance in Auto
 in
Dryer Repair
Trying to troubleshoot an old Whirlpool dryer. The timer will not advance in Auto mode but the timer works fine
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer - Timer Won't Advance in Auto
  #1 (permalink)
Old 12-10-2016, 12:18 PM
Junior Member
AMarkham40 is on a distinguished road
Default Whirlpool Dryer - Timer Won't Advance in Auto
Model Number: le6150xsw0   Brand: Whirlpool   Age: More than 10 years
Trying to troubleshoot an old Whirlpool dryer. The timer will not advance in Auto mode but the timer works fine in Timed Mode. The dryer is producing heat in both modes. I have made sure the dryer is free of any lint. I tested the resistor going to the auto timer & it measured around 4400 ohms which tells me the resistor is fine. Where should I look next? I attached a picture of the wiring diagram on the back of the dryer.
Related Models
Whirlpool LE6150XSW0 Residential Dryer
Whirlpool LE6150XSW1 Residential Dryer
Whirlpool LE6400XKW0 Residential Dryer
Whirlpool LE6400XPW0 Residential Dryer
Whirlpool LE6400XSW0 Residential Dryer
Whirlpool LE6405XPW0 Residential Dryer
Whirlpool LE6600XPW0 Residential Dryer
Whirlpool LE6600XSW0 Residential Dryer
Whirlpool LE6605XPW0 Residential Dryer
Whirlpool LE6605XPW1 Residential Dryer
Whirlpool LE6680XPW0 Residential Dryer
Whirlpool LE6680XSW0 Residential Dryer
Whirlpool LE6685XPW0 Residential Dryer
Whirlpool LE6685XPW1 Residential Dryer
Whirlpool LE6800XPW0 Residential Dryer
Whirlpool LE6800XSW0 Residential Dryer
Whirlpool LE6800XTG0
Whirlpool LE6800XTN0
Whirlpool LE6800XTW0 Residential Dryer
Whirlpool LE6805XPW0 Residential Dryer
Whirlpool LE6810XPW0 Residential Dryer
Whirlpool LE6810XSW0 Residential Dryer
Whirlpool LE6880XSW0 Residential Dryer
Whirlpool LE6880XSW1 Residential Dryer
Whirlpool LE6880XTW0 Residential Dryer
Whirlpool LE6880XTW1 Residential Dryer
Whirlpool LE7000XMW0 Residential Dryer
Whirlpool LE7000XMW1 Residential Dryer
Whirlpool LE7000XMW2 Residential Dryer
Whirlpool LE7000XPW0 Residential Dryer
Whirlpool LE7000XSW0 Residential Dryer
Whirlpool LE7000XTG0
Whirlpool LE7000XTN0
Whirlpool LE7000XTW0 Residential Dryer
Whirlpool LE7005XPW0 Residential Dryer
Whirlpool LE7010XPW0 Residential Dryer
Whirlpool LE7010XSW0 Residential Dryer
Whirlpool LE7080XSW0 Residential Dryer
Whirlpool LE7080XSW1 Residential Dryer
Whirlpool LE7080XTW0 Residential Dryer
Whirlpool LE7080XTW1 Residential Dryer
Amana LE7101LB DRYER- ELE
Amana LE7101WB DRYER- ELE
Amana LE7111LB DRYER- ELE
Amana LE7111LM DRYER- ELE
Amana LE7111WB DRYER- ELE
Amana LE7111WM DRYER- ELE
Amana LE7121LM DRYER- ELE
Amana LE7121WM DRYER- ELE
Amana LE7153LB DRYER- ELE
Amana LE7153LM DRYER- ELE
Amana LE7153WB DRYER- ELE
Amana LE7153WM DRYER- ELE
Amana LE7163LM DRYER- ELE
Amana LE7163WM DRYER- ELE
Whirlpool LE7680XMW0 Residential Dryer
Whirlpool LE7680XPW0 Residential Dryer
Whirlpool LE7680XSW0 Residential Dryer
Whirlpool LE7680XSW1 Residential Dryer
Whirlpool LE7680XSW2 Residential Dryer
Whirlpool LE7685XPW0 Residential Dryer
Whirlpool LE7685XPW1 Residential Dryer
Whirlpool LE7700XWW0 Residential Dryer
Whirlpool LE7760XWW0 Residential Dryer
Whirlpool LE7800XKW0 Residential Dryer
Whirlpool LE7800XKW1 Residential Dryer
Whirlpool LE7800XMW0 Residential Dryer
Whirlpool LE7800XMW1 Residential Dryer
Whirlpool LE7800XMW2 Residential Dryer
Whirlpool LE7800XPW0 Residential Dryer
Whirlpool LE7800XSN2 ELECTRIC DRYER
Whirlpool LE7800XSW0 Residential Dryer
Whirlpool LE7800XSW1 Residential Dryer
Whirlpool LE7800XSW2 Residential Dryer
Whirlpool LE7800XSW3 Residential Dryer
Whirlpool LE7800XW2 ELECTRIC DRYER
Whirlpool LE7805XPW0 Residential Dryer
Whirlpool LE7810XPW0 Residential Dryer
Amana LE8107L2 WASHER-TOP LOADING
Amana LE8107W2 DRYER- ELE
Amana LE8207L2 WASHER-TOP LOADING
Amana LE8207L3 WASHER-TOP LOADING
Amana LE8207W2 DRYER- ELE
Amana LE8207W2B DRYER- ELE
Amana LE8207W3 DRYER- ELE
Amana LE8217L2 DRYER- ELE
Amana LE8217W2 DRYER- ELE
Amana LE8267L2 WASHER-TOP LOADING
Amana LE8267W2 DRYER- ELE
Amana LE8317L2 DRYER- ELE
Amana LE8317W2 DRYER- ELE
Amana LE8317W2B DRYER- ELE
Amana LE8327W DRYER- ELE
Amana LE8367L2 WASHER-TOP LOADING
Amana LE8367W2 DRYER- ELE
Amana LE8407L2 DRYER- ELE
Amana LE8407W DRYER- ELE
Amana LE8407W2 DRYER- ELE
Amana LE8457L2 DRYER- ELE
Amana LE8457W DRYER- ELE
Amana LE8457W2 DRYER- ELE
Amana LE8467L2 DRYER- ELE
Amana LE8467W2 DRYER- ELE
Amana LE8507W DRYER- ELE
Amana LE8517L2 DRYER- ELE
Amana LE8517W2 DRYER- ELE
Amana LE8517W2B DRYER- ELE
Amana LE8567L2 DRYER- ELE
Amana LE8567W2 DRYER- ELE
Whirlpool LE8600XWW0 Residential Dryer
Amana LE8607L2 DRYER- ELE
Amana LE8607W DRYER- ELE
Amana LE8607W2 DRYER- ELE
Whirlpool LE8650XWW0 Residential Dryer
Whirlpool LE8860XWQ0 Residential Dryer
Amana LE9002 WASHER-TOP LOADING
Amana LE9002 DRYER- ELE
Amana LE9012 WASHER-TOP LOADING
Whirlpool LE9100XTW0 Residential Dryer
Whirlpool LE9100XTW1 Residential Dryer
  #2 (permalink)
Old 12-10-2016, 12:36 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
You need to check the timer. See the part of the wiring diagram that says "timer schedule in minutes" ?
Notice the auto cycles have something the timed doesn't. TM to RS1
So with the dryer unplugged and the timer set in about the center of an auto cycle, you should get a continuity reading through TM to RS1. Check with the wires off the terminals to make sure.
If you don't then the timer is bad.
  #3 (permalink)
Old 12-10-2016, 12:47 PM
Junior Member
Default
Ok, I checked continuity across TM to RS1 in Auto Mode & Timed Mode. In Auto Mode my multi meter beeps showing continuity. In Timed Mode it showed no continuity. I then tested TM to CS while in Timed Mode & the multi meter beeped showing continuity. I'm guessing this is correct.
  #4 (permalink)
Old 12-10-2016, 01:03 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
It should be.
The timer terminal RS1 goes to one end of the resistor. The other end of the resistor goes down to the same wire that goes to H1. Which is one side of the heater element.
Check for bad or broken connections. You said it was heating in auto, so voltage has to be present.
  #5 (permalink)
Old 12-10-2016, 01:19 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Boy, you can tell I haven't done this in awhile. You probably have a bad cycling thermostat.
Whirlpool WP694674 Adjustable Dryer Cycling Thermostat - AppliancePartsPros.com
Also check the bias heater under it. It should be around 3240 to 3960 ohms. I have no idea why they are calling it a thermostat.
Whirlpool WP61894 Thermostat - AppliancePartsPros.com
It could just be the bias heater causing the problem.
  #6 (permalink)
Old 12-10-2016, 01:35 PM
Junior Member
Default
I checked the bias heater earlier & it was around 3600 ohms. Where on the diagram is the cycling thermostat? Thanks for all your help!
  #7 (permalink)
Old 12-10-2016, 02:52 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
The cycling thermostat also known as the operational thermostat is shown as "oper. stat" on the diagram.
Also check Y to RL on the timer. They power the bias heater under the oper, stat.
  #8 (permalink)
Old 12-10-2016, 03:24 PM
Junior Member
Default
I removed one of the leads from the cycling thermostat & started the dryer (simulating an open thermostat). With the lead removed the timer was advancing in Auto mode. I will try & replace the thermostat next week. Thank you again!
  #9 (permalink)
Old 12-10-2016, 03:41 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Check that the bias heater is getting 120 volts from the timer. That heater heats the oper. stat so the clothes can dry at a lower temperature and the timer will advance more often in an auto cycle like permanent press.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool (Roper) electric dryer runs and heats. Timer does not advance in auto or ti biomed172 Dryer Repair 1 10-11-2014 05:30 AM
Dryer timer won't advance in Auto teppler Dryer Repair 0 03-12-2014 07:55 AM
dryer timer/cycle will not advance on auto setting treehugger Dryer Repair 8 01-05-2011 05:54 AM
GE dryer timer won't advance in auto mode jwysocky Dryer Repair 7 02-25-2010 02:54 PM
GE Dryer- Timer will not advance in Auto dalbers Dryer Repair 0 12-09-2008 06:36 PM
