I need help! This morning I was drying a load of clothes in my Whirlpool Duet Dryer and when I went to check them, there was condensation on the door, the timer had counted down, but the dryer had never tumbled. I hit stop, turned it back on and it seemed fine. Went to dry my second load and now the buttons all light up, but when I hit start, it just clicks. I did some research online and read that this is a common problem with the Thermal Fuse. I replaced that, but it didn't do anything. I ran through all the diagnostic codes and no codes come back indicating a problem.
What else could this be?
