Discuss
No Start
 in
Dryer Repair
Complaint, will not start. Sensor light comes on. Diagnostic displays F1 error, primary control failure. No other errors in the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Start
  #1 (permalink)
Old 11-21-2016, 09:11 AM
Junior Member
jjuly is on a distinguished road
Default No Start
Model Number: WGD6400SW2   Brand: Whirlpool   Age: 1 - 5 years
Diagnostic displays F1 error, primary control failure. No other errors in the memory.
Replaced the board WPW10111617
Start attempt ... same thing. No start, sensor light comes on.
Error now is F2: keypad stuck. Performed tests and the result would be to replace the user interface board. WP8563974
No other errors in memory. Placing the old main board, back to F1 and no other.
Wow, the first board was $236 and if it also needs the second, that's another $265
Also, the repair page said: "control is glued to panel. Panel could be damaged during replacement"
Looking for your advise.
Related Models
Whirlpool WGD6400SW2 29" GAS DRYER
Whirlpool WGD6600VU0 29" GAS DRYER
Whirlpool WGD6600VU1 29" GAS DRYER
Whirlpool WGD6600VW0 29" GAS DRYER
Whirlpool WGD6600VW1 29" GAS DRYER
Whirlpool WGD6600WL0 29"GAS DRYER
Whirlpool WGD7300XW0 27" ELECTRIC DRYER
Whirlpool WGD7400XW0 27" GAS DRYER
Whirlpool WGD7600XW0 27" GAS DRYER
Whirlpool WGD7800XB0 27" GAS DRYER
Whirlpool WGD7800XL0 27" GAS DRYER
Whirlpool WGD7800XW0 27" GAS DRYER
Whirlpool WGD7990XG0 DRYER
Whirlpool WGD8200YW0 DRYER
Whirlpool WGD8300SB0 27" GAS DRYER
Whirlpool WGD8300SB1 27" GAS DRYER
Whirlpool WGD8300SB2 27" GAS DRYER
Whirlpool WGD8300SE2 27" GAS DRYER
Whirlpool WGD8300SW0 27" GAS DRYER
Whirlpool WGD8300SW1 27" GAS DRYER
Whirlpool WGD8300SW2 27" GAS DRYER
Whirlpool WGD8410SW0 27"GAS DRYER
Whirlpool WGD8410SW1 27" GAS DRYER
Whirlpool WGD8500SR0 27"GAS DRYER
Whirlpool WGD8500SR1 27" GAS DRYER
Whirlpool WGD8600YW0 DRYER
Whirlpool WGD8800YC0 27" GAS DRYER
Whirlpool WGD8800YW0 27" GAS DRYER
Whirlpool WGD9050XW0 27" GAS DRYER
Whirlpool WGD9050XW1 GAS DRYER
Whirlpool WGD9150WW0 27" GAS DRYER
Whirlpool WGD9150WW1 27" GAS DRYER
Whirlpool WGD9151YW0 27" GAS DRYER
Whirlpool WGD9200SQ0 GAS DRYER
Whirlpool WGD9200SQ1 GAS DRYER
Whirlpool WGD9250WL0 27" GAS DRYER
Whirlpool WGD9250WR0 27" GAS DRYER
Whirlpool WGD9250WW0 27" GAS DRYER
Whirlpool WGD9270XL0 27"GAS DRYER
Whirlpool WGD9270XL1 27" GAS DRYER
Whirlpool WGD9270XR0 27"GAS DRYER
Whirlpool WGD9270XR1 27" GAS DRYER
Whirlpool WGD9270XW0 27"GAS DRYER
Whirlpool WGD9270XW1 27" GAS DRYER
Whirlpool WGD9300VU0 GAS DRYER
Whirlpool WGD9300VU1 GAS DRYER
Whirlpool WGD9371YL0 27" GAS DRYER
Whirlpool WGD9371YW0 27" GAS DRYER
Whirlpool WGD9400SB0 GAS DRYER
Whirlpool WGD9400SB1 GAS DRYER
Whirlpool WGD9400ST0 GAS DRYER
Whirlpool WGD9400ST1 GAS DRYER
Whirlpool WGD9400SU0 GAS DRYER
Whirlpool WGD9400SU1 GAS DRYER
Whirlpool WGD9400SW0 GAS DRYER
Whirlpool WGD9400SW1 GAS DRYER
Whirlpool WGD9400SW2 GAS DRYER
Whirlpool WGD9400SW3 GAS DRYER
Whirlpool WGD9400SZ0 GAS DRYER
Whirlpool WGD9400SZ1 GAS DRYER
Whirlpool WGD9400SZ2 GAS DRYER
Whirlpool WGD9400SZ3 GAS DRYER
Whirlpool WGD9400VE0 GAS DRYER
Whirlpool WGD9400VE1 GAS DRYER
Whirlpool WGD9450WL0 GAS DRYER
Whirlpool WGD9450WL1 GAS DRYER
Whirlpool WGD9450WL2 GAS DRYER
Whirlpool WGD9450WR0 GAS DRYER
Whirlpool WGD9450WR1 GAS DRYER
Whirlpool WGD9450WR2 GAS DRYER
Whirlpool WGD9450WW0 GAS DRYER
Whirlpool WGD9450WW1 GAS DRYER
Whirlpool WGD9450WW2 GAS DRYER
Whirlpool WGD9470WL1 GAS DRYER
Whirlpool WGD9470WL2 GAS DRYER
Whirlpool WGD9470WR1 GAS DRYER
Whirlpool WGD9470WR2 GAS DRYER
Whirlpool WGD9470WW1 GAS DRYER
Whirlpool WGD9470WW2 GAS DRYER
Whirlpool WGD94HEXL0 DRYER
Whirlpool WGD94HEXL1 27" GAS DRYER
Whirlpool WGD94HEXR0 DRYER
Whirlpool WGD94HEXR1 27" GAS DRYER
Whirlpool WGD94HEXW0 DRYER
Whirlpool WGD94HEXW1 27" GAS DRYER
Whirlpool WGD9500TC0 GAS DRYER
Whirlpool WGD9500TC1 GAS DRYER
Whirlpool WGD9500TC2 GAS DRYER
Whirlpool WGD9500TU0 GAS DRYER
Whirlpool WGD9500TU1 GAS DRYER
Whirlpool WGD9500TW0 GAS DRYER
Whirlpool WGD9500TW1 GAS DRYER
Whirlpool WGD9500TW2 GAS DRYER
Whirlpool WGD9500TW3 GAS DRYER
Whirlpool WGD9500TW4 GAS DRYER
Whirlpool WGD9550WL0 GAS DRYER
Whirlpool WGD9550WL1 GAS DRYER
Whirlpool WGD9550WL2 GAS DRYER
Whirlpool WGD9550WR0 GAS DRYER
Whirlpool WGD9550WR1 GAS DRYER
Whirlpool WGD9550WR2 GAS DRYER
Whirlpool WGD9550WW0 GAS DRYER
Whirlpool WGD9550WW1 GAS DRYER
Whirlpool WGD9550WW2 GAS DRYER
Whirlpool WGD95HEXL0 DRYER
Whirlpool WGD95HEXL1 27" GAS DRYER
Whirlpool WGD95HEXR0 DRYER
Whirlpool WGD95HEXR1 27" GAS DRYER
Whirlpool WGD95HEXW0 DRYER
Whirlpool WGD95HEXW1 27" GAS DRYER
Whirlpool WGD9600SU0 GAS DRYER
Whirlpool WGD9600TA0 27" GAS DRYER
Whirlpool WGD9600TA1 27" GAS DRYER
Whirlpool WGD9600TA2 27" GAS DRYER
Whirlpool WGD9600TB0 27" GAS DRYER
Whirlpool WGD9600TB1 27" GAS DRYER
Whirlpool WGD9600TU0 27" GAS DRYER
Whirlpool WGD9600TU1 27" GAS DRYER
Whirlpool WGD9600TW0 27" GAS DRYER
Whirlpool WGD9600TW1 27" GAS DRYER
  #2 (permalink)
Old 11-21-2016, 02:14 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Check all the connections to the computer and touch panel. Re-seat them and see if it makes a difference.
On some older dryers "F2" can be a thermister problem. I'd check it just to rule it out. If you're not sure how here is a video about it.
https://www.youtube.com/watch?v=oaABV5WV6sI
Part no. 9 on this diagram.
Parts for Whirlpool WGD6400SW2: Bulkhead Parts - AppliancePartsPros.com
  #3 (permalink)
Old 11-21-2016, 04:23 PM
Junior Member
Default
Thanks, although I did check the connectors on the main board, I'll go back and check again, as well as checking the temp thermistor and running more of the diagnostic tests.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Must use delayed start to start cycle start button won't work Loucalabrese@charter.net Dishwasher Repair 1 08-13-2016 06:33 PM
Will Not Start Panel Light Up But Wont Start When Start Button Is Pressed lillisab47 Dishwasher Repair 0 12-11-2014 09:21 AM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dryer Repair 0 03-28-2011 03:21 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dishwasher Repair 0 03-28-2011 12:13 PM
Dryer will not start - will power up, but when push the start button, will not start perduena Dryer Repair 0 07-12-2010 07:14 PM
