ctfeddy
#1 Posted : Monday, November 2, 2009 7:52:28 AM(UTC)
ctfeddy
Dryer suddenly stopped heating. Drum rotates, but no heat. Thinking it is probably the heating element, thermostat or both? Have been trying to find the right repair parts, which are listed as 660982 and/or 695563. Do you think it's worth replacing them since it is so old? Has always worked really well.
#2 Posted : Tuesday, November 3, 2009 5:01:07 AM(UTC)
First I would flip the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts.
Better yet measure it with a meter.
Heating element
Part number: AP3109438
Hi-Limit thermostat
Part number: AP3094224
Depends on what it will cost to repair, how good of shape the unit is in and how happy you are with it.
I would open it up find out what is causing the no heat problem.
Then I would check the unit over. Check the belt, rear rollers, front supports, idler wheel, drum seals etc. for wear and bearing slop.
You may as well do a basic overhaul while you have it open.
This also will give you a total cost of repair.
ctfeddy
#3 Posted : Tuesday, November 3, 2009 6:57:40 PM(UTC)
ctfeddy
denman,
Will take your advice and do an overhaul of the dryer. Thank you.
ctfeddy
