Discuss
Need advice on LG dryer, it is not rolling
 in
Dryer Repair
Hi there, I need some advice on what options I have for this LG dryer. Thanks in advance. This is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Need advice on LG dryer, it is not rolling
  #1 (permalink)
Old 10-30-2016, 08:51 PM
Junior Member
wxppro is on a distinguished road
Question Need advice on LG dryer, it is not rolling
Model Number: LG SteamDryer DLEY1201W   Brand: -other-   Age: 1 - 5 years
Hi there,
This is an LG SteamDryer that is only 2 years old. The model number is DLEY1201W. What happened was that it suddenly stopped rolling during a run. Here is the symptom and what I have examined.
Press the Power button, the dryer can be turned on. The panel displays the usual lights. "Check Filter" light blinks. Press the cycle selection button to select one cycle. "Check Filter" light goes off. The "Dry" light turns on. When the Start button is pressed, the dryer makes a few clicking sound, the "Dry" light blinks, but the machine is not rolling at all. Basically, nothing happens.
I have attempted to bypass the thermostat and thermal fuse. No change at all. So they do not seem to be the cause of the problem. I have also tested the door switch - with the door open, press Start button, the dryer does nothing but also does not make any clicking sound. So it seems the door switch is working fine.
I checked the lint filter and vent pipe - all clean.
So, any other simple and quick checks I can do? Does it mean that the problem is with the control board or the heat element? It is a quite new machine and has not been extensively used (just once or twice a week).
Any advice is appreciated. Thanks!
Related Models
Amana LG1009W DRYER- GAS
Amana LG1101 DRYER- GAS
Amana LG1112 WASHER-TOP LOADING
Amana LG1112 DRYER- GAS
Whirlpool LG2001XSW0 Residential Dryer
Amana LG2112L DRYER- GAS
Amana LG2112W DRYER- GAS
Amana LG2401 DRYER- GAS
Amana LG2412 WASHER-TOP LOADING
Amana LG2412 DRYER- GAS
Amana LG2501 DRYER- GAS
Amana LG2512 WASHER-TOP LOADING
Amana LG2512 DRYER- GAS
Amana LG2811 DRYER- GAS
Amana LG2812 WASHER-TOP LOADING
Amana LG2812 DRYER- GAS
Amana LG2902 WASHER-TOP LOADING
Amana LG2911 DRYER- GAS
Amana LG2912 WASHER-TOP LOADING
Amana LG2912 DRYER- GAS
Whirlpool LG3001XMW0 Residential Dryer
Whirlpool LG3001XMW1 Residential Dryer
Whirlpool LG3001XMW2 Residential Dryer
Whirlpool LG3001XPW0 Residential Dryer
Whirlpool LG3001XSW0 Residential Dryer
Whirlpool LG3006XPW0 Residential Dryer
Amana LG3412G DRYER- GAS
Amana LG3412L DRYER- GAS
Amana LG3412W DRYER- GAS
Amana LG3512L DRYER- GAS
Amana LG3512W DRYER- GAS
Amana LG3812L DRYER- GAS
Amana LG3812W DRYER- GAS
Amana LG3912L DRYER- GAS
Amana LG3912W DRYER- GAS
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L DRYER- GAS
Amana LG4209L2 DRYER- GAS
Amana LG4209W DRYER- GAS
Amana LG4209W2 DRYER- GAS
Amana LG4219L2 DRYER- GAS
Amana LG4219W2 DRYER- GAS
Amana LG4309L DRYER- GAS
Amana LG4309W DRYER- GAS
Amana LG4319L2 DRYER- GAS
Amana LG4319W2 DRYER- GAS
Amana LG4409L DRYER- GAS
Amana LG4409W DRYER- GAS
Amana LG4429L DRYER- GAS
Amana LG4429W DRYER- GAS
Whirlpool LG4441XWW0 Residential Dryer
Whirlpool LG4441XWW1 Residential Dryer
Amana LG4509L DRYER- GAS
Amana LG4509W DRYER- GAS
Amana LG4609L DRYER- GAS
Amana LG4609W DRYER- GAS
Amana LG4809L DRYER- GAS
Amana LG4809W DRYER- GAS
Amana LG4909L DRYER- GAS
Amana LG4909W DRYER- GAS
Whirlpool LG4931XMW0 Residential Dryer
Whirlpool LG4931XSW0 Residential Dryer
Whirlpool LG4931XTW0 Residential Dryer
Whirlpool LG4931XTW1 Residential Dryer
Whirlpool LG4931XTW2 Residential Dryer
Whirlpool LG4936XMW0 Residential Dryer
Whirlpool LG4936XMW1 Residential Dryer
Whirlpool LG5201XTW0 Residential Dryer
Whirlpool LG5201XTW1 Residential Dryer
Whirlpool LG5321XTW0 Residential Dryer
Whirlpool LG5531XKW0 Residential Dryer
Whirlpool LG5531XKW1 Residential Dryer
Whirlpool LG5531XMG2 GAS DRYER
Whirlpool LG5531XMN2 GAS DRYER
Whirlpool LG5531XMW0 Residential Dryer
Whirlpool LG5531XMW1 Residential Dryer
Whirlpool LG5531XMW2 GAS DRYER
Whirlpool LG5531XPW0 Residential Dryer
Whirlpool LG5531XSW0 Residential Dryer
Whirlpool LG5531XSW1 Residential Dryer
Whirlpool LG5536XPW0 Residential Dryer
Whirlpool LG5551XTG0 GAS DRYER
Whirlpool LG5551XTN0 GAS DRYER
Whirlpool LG5551XTW0 Residential Dryer
Whirlpool LG5601XMW0 Residential Dryer
Whirlpool LG5601XPW0 Residential Dryer
Whirlpool LG5601XSW0 Residential Dryer
Whirlpool LG5601XSW1 Residential Dryer
Whirlpool LG5606XPW0 Residential Dryer
Whirlpool LG5651XKW0 Residential Dryer
Whirlpool LG5651XKW1 Residential Dryer
Whirlpool LG5651XMW0 Residential Dryer
Whirlpool LG5651XMW1 Residential Dryer
Whirlpool LG5701XKW0 Residential Dryer
Whirlpool LG5701XMW0 Residential Dryer
Whirlpool LG5701XMW1 Residential Dryer
Whirlpool LG5701XMW2 Residential Dryer
Whirlpool LG5701XPW0 Residential Dryer
Whirlpool LG5701XSN0 GAS DRYER
Whirlpool LG5701XSW0 Residential Dryer
Whirlpool LG5706XPW0 Residential Dryer
Whirlpool LG5721XPW0 Residential Dryer
Whirlpool LG5721XSW0 Residential Dryer
Whirlpool LG5721XSW1 Residential Dryer
Whirlpool LG5726XPW0 Residential Dryer
Whirlpool LG5751XFW0 Residential Dryer
Whirlpool LG5751XKW0 Residential Dryer
Whirlpool LG5751XKW1 Residential Dryer
Whirlpool LG5751XMW0 Residential Dryer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Samsung Dryer Tub Making Noise When Rolling veda1 Washer Repair 0 02-09-2016 05:35 PM
Making sound while rolling amelathe Dryer Repair 2 10-06-2009 04:29 AM
