Alito
#1 Posted : Thursday, October 27, 2016 6:02:25 PM(UTC)
Alito
Dryer not heating change thermistor, fuse ,thermostat , PCB board, still not heating, check the touch sensor (adjust time up +temp press key for 7sec) is ok dry 0 wet cloth 1 , then check the motor and heater the result is OK on the display ( by the way is the only time the heater work) Jumping the heater relay work too . So next to change the sub board (display and dial) ?
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Samsung dryer not heating (Dryer Repair)
by oakback 9/17/2016 8:17:04 AM(UTC)
Samsung Dryer Not Heating (Dryer Repair)
by jgrover 2/29/2012 7:13:17 AM(UTC)
Samsung Dryer Not heating (Dryer Repair)
by auntiem1967 8/31/2011 9:39:56 AM(UTC)
