Discuss
Dryer humming when starting but drum will not turn
 in
Dryer Repair
When I hit the start button on my Kenmore dryer the motor is humming but the drum will not turn.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer humming when starting but drum will not turn
  #1 (permalink)
Old 11-02-2009, 06:44 AM
heidi1005 heidi1005 is offline
Junior Member
heidi1005 is on a distinguished road
Default Dryer humming when starting but drum will not turn
Brand: Kenmore   Age: 5 - 10 years
When I hit the start button on my Kenmore dryer the motor is humming but the drum will not turn. Any suggestions?
  #2 (permalink)
Old 11-02-2009, 09:27 PM
Qtip Qtip is offline
Member
Qtip is on a distinguished road
Default
Most likely is a bad motor - sometimes can be started using odd instructions. 1-Open door and hold down door switch with one hand2- Hold down start button with second hand3- Manually spin drum with third hand (probably need two people for this)If dryer starts that way then motor is bad (this could temporarily buy you some time to get parts or new dryer) If dryer still doesnt start then something (usually sock) could be stuck in blower wheel.
  #3 (permalink)
Old 11-02-2009, 10:37 PM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
If you have heat, your belt is probably broken.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Push Switch get humming sound drum doesn't turn mikesi Dryer Repair 1 10-30-2009 05:16 PM
dryer drum will not turn on rturner Dryer Repair 1 06-29-2008 11:17 AM
dryer drum won't turn coolrunning Dryer Repair 2 04-15-2008 12:58 PM
Dryer Drum Won't Turn PSINKHORN Dryer Repair 1 10-28-2007 08:41 PM
