| » Matag dryer turns on by itself |
Model Number: MDE6800AYW Brand: Maytag Age: 5 - 10 years
Our dryer will turn itself back on after pushing the off button. I have to turn the breaker off in order to turn the dryer off. It will also go to the sensor dry cycle by itself no matter what type of drying cycle is selected. (time dry, wrinkle release, air fluff, etc) I replaced the circuit board in the control panel thinking this was all it could be. No luck. Still doing what it wants. It dries the clothes fine, but will not stop or go into the cool down mode when the clothes are dry. Any help or suggestions appreciated.
Rick Ads By Google Related Models |
Here is a manual which may help
http://www.servicematters.com/maytag...s/16023110.pdf Try to run the diagnostics. This is going to be a shot in the dark as like you I would have though the control board was the problem. I am assuming that this unit used to work correctly at this location. Clean your sensor bars with isopropyl alcohol. Check that earth ground is connected correctly as I see they have a separate earth ground going to the board. Hopefully someone else will have some more concrete help.
__________________
| Display Modes | |
| Dryer Dosent Dry And Never Turns Off | IZA0401 | Dryer Repair | 1 | 08-21-2009 04:30 PM |
| Dryer turns off | Jarhead72 | Dryer Repair | 1 | 06-27-2009 09:43 AM |
| Matag Gas Dryer stopped spinning | garysk | Dryer Repair | 1 | 04-23-2009 08:55 PM |
| Neptune Matag Dryer | karen d covell | Dryer Repair | 2 | 01-24-2009 05:13 AM |
| Dryer just turns off | Mepenn | Dryer Repair | 1 | 10-14-2008 06:33 PM |
