scm518
#1 Posted : Friday, October 7, 2016 4:32:36 AM(UTC)
scm518
Hello!
The dryer functions - however does not produce heat. I purchased new thermal fuses and a new igniter and installed those last night, unfortunately without any success.
The igniter does not glow, and I do no smell any gas. I am on the verge of reading this unit its last rights. Can anyone suggest a part that may be the culprit before I make the decision to recycle this old friend?
Thank You
Sean
ThatGuy
#2 Posted : Friday, October 7, 2016 5:58:19 PM(UTC)
ThatGuy
Groups: Expert
United States
Have you checked the gas valve coils? They could be the problem. There is a nice video on the page too.
Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
The wiring diagram is here. There are 9 parts in circuit to make your dryer heat. Including the timer and motor's centrifugal switch. Good luck.
Parts for Magic Chef YG206KW: Wiring Information Parts - AppliancePartsPros.com
scm518
#3 Posted : Saturday, October 8, 2016 4:47:27 AM(UTC)
scm518
Thatguy,
Thank you for your post.
I did not check them, however I just went over and disconnected the wiring to each of them and checked for continuity. I am not sure if that is a valid test for these items - but both of them failed for continuity. The one with two prongs was an easy test, and for the one with three prongs, I tested it with all the 2 prong combinations - and none of them showed continuity. Is this a part that should show continuity? Also - if I replace these do I need to shut off the gas service before replacing. The way the original owner of the house built this laundry room, I would have to disconnect the utility sink completely and move it out of the way in order to get to the gas valve.
As for the diagram, I have now either replaced or tested a few of those parts. Depending on your guidance on the above question I will not do anything further until I hear from you.
Thank you very much for your time and assistance,
ThatGuy
#4 Posted : Saturday, October 8, 2016 7:32:23 AM(UTC)
ThatGuy
Groups: Expert
United States
This video does a pretty good job of explaining how to test the coils.
https://www.youtube.com/watch?v=vzqGJoNwKRE
scm518
#5 Posted : Saturday, October 8, 2016 3:05:31 PM(UTC)
scm518
Just installed the new coils.
Still nothing.
I am going to have to start from the timer on downward and see what is not firing up.
Dryer not producing heat (Dryer Repair)
by cao824 6/5/2017 8:37:33 AM(UTC)
dryer not producing heat (Dryer Repair)
by mscerbak 2/14/2014 5:00:09 PM(UTC)
Electric Dryer Not Producing Heat & Timer Does Not Advance in Auto Dry Settings (Dryer Repair)
by hifroggyjenn 1/12/2012 10:26:47 AM(UTC)
Frigidaire dryer not producing heat after replacing main components. (Dryer Repair)
by LooseBoltsRob 12/20/2011 8:11:28 AM(UTC)
by Jeff B 1/6/2008 2:16:16 PM(UTC)
