Discuss
WP dryer runs 20 mins and stops, wait 15 min and it goes another 20 mins
 in
Dryer Repair
My Whirlpool dryer will run and heat for 20 minutes and stop running. If I wait 15 to 20 minutes
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » WP dryer runs 20 mins and stops, wait 15 min and it goes another 20 mins
  #1 (permalink)
Old 10-03-2016, 11:26 AM
Junior Member
jtrox is on a distinguished road
Default WP dryer runs 20 mins and stops, wait 15 min and it goes another 20 mins
Model Number: LEB6200PQ0   Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool dryer will run and heat for 20 minutes and stop running. If I wait 15 to 20 minutes it will start back up and run another 20 minutes and stop again. If I wait another 20 minutes it will start back up and finish the load. I checked the vent for blockage and looks good, plenty of airflow as well. I check the Hi T-Stat for continuity right after it stops and it appears to be closed or have zero resistance. The internal bias T-Stat also shows continuity. What switch will stop the motor from running until it cools down???? I haven't seen the wire diagram yet but I haven't opened the top panel so it might be there. Is there a wire diagram for this model on line somewhere?
Related Models
Whirlpool LEB6200PQ0 29" ELECTRIC DRYER
Whirlpool LEB6200PQ1 29"ELECTRIC DRYER
Whirlpool LEB6300LW0 RESIDENTIAL DRYER
Whirlpool LEB6300LW1 29"ELECTRIC DRYER
Whirlpool LEB6300PW0 29"ELECTRIC DRYER
Whirlpool LEB6300PW1 29"ELECTRIC DRYER
Whirlpool LEB6400KQ0 RESIDENTIAL DRYER
Whirlpool LEB6400KQ1 RESIDENTIAL DRYER
Whirlpool LEB6400LW0 RESIDENTIAL DRYER
Whirlpool LEB6400LW1 29"ELECTRIC DRYER
Amana LEC10AW DRYER- ELE
Admiral LEC1330AAB SURFACE UNIT- ELE
Admiral LEC1330AAC SURFACE UNIT- ELE
Admiral LEC1330AAW SURFACE UNIT- ELE
Amana LEC20AW DRYER- ELE
Amana LEC30AW DRYER- ELE
Amana LEC32AW DRYER- ELE
Whirlpool LEC5000PQ0 29" ELECTRIC DRYER
Whirlpool LEC5000PQ1 29" ELECTRIC DRYER
Amana LEC50AW DRYER- ELE
Amana LEC60AW DRYER- ELE
Whirlpool LEC6646AN0 ELECTRIC DRYER
Whirlpool LEC6646AN1 ELECTRIC DRYER
Whirlpool LEC6646AN2 ELECTRIC DRYER
Whirlpool LEC6646AQ0 Residential Dryer
Whirlpool LEC6646AQ1 ELECTRIC DRYER
Whirlpool LEC6646AQ2 ELECTRIC DRYER
Whirlpool LEC6646AW0 Residential Dryer
Whirlpool LEC6646AW1 ELECTRIC DRYER
Whirlpool LEC6646AW2 ELECTRIC DRYER
Whirlpool LEC6646AZ1 ELECTRIC DRYER
Whirlpool LEC6646AZ2 ELECTRIC DRYER
Whirlpool LEC6646AZO ELECTRIC DRYER
Whirlpool LEC6848AN0 ELECTRIC DRYER
Whirlpool LEC6848AN1 ELECTRIC DRYER
Whirlpool LEC6848AN2 ELECTRIC DRYER
Whirlpool LEC6848AN3 ELECTRIC DRYER
Whirlpool LEC6848AQ0 Residential Dryer
Whirlpool LEC6848AQ1 ELECTRIC DRYER
Whirlpool LEC6848AQ2 ELECTRIC DRYER
Whirlpool LEC6848AQ3 ELECTRIC DRYER
Whirlpool LEC6848AW0 ELECTRIC DRYER
Whirlpool LEC6848AW1 TECH SHEET - DRYER - REVISION REL.
Whirlpool LEC6848AW2 ELECTRIC DRYER
Whirlpool LEC6848AW3 ELECTRIC DRYER
Whirlpool LEC6848AZ1 ELECTRIC DRYER
Whirlpool LEC6848AZ2 ELECTRIC DRYER
Whirlpool LEC6848AZ3 ELECTRIC DRYER
Whirlpool LEC6858AQ3 ELECTRIC DRYER
Whirlpool LEC7646DQ0 ELECTRIC DRYER
Whirlpool LEC7646DQ1 ELECTRIC DRYER
Whirlpool LEC7646DZ0 ELECTRIC DRYER
Whirlpool LEC7646DZ1 ELECTRIC DRYER
Whirlpool LEC7848DQ0 ELECTRIC DRYER
Whirlpool LEC7848DQ1 ELECTRIC DRYER
Whirlpool LEC7848DZ0 ELECTRIC DRYER
Whirlpool LEC7848DZ1 ELECTRIC DRYER
Whirlpool LEC7858AN0 ELECTRIC DRYER
Whirlpool LEC7858AN1 ELECTRIC DRYER
Whirlpool LEC7858AN2 ELECTRIC DRYER
Whirlpool LEC7858AQ0 ELECTRIC DRYER
Whirlpool LEC7858AQ1 ELECTRIC DRYER
Whirlpool LEC7858AQ2 ELECTRIC DRYER
Whirlpool LEC7858AW0 Residential Dryer
Whirlpool LEC7858AW1 ELECTRIC DRYER
Whirlpool LEC7858AW2 ELECTRIC DRYER
Whirlpool LEC7858AZ0 ELECTRIC DRYER
Whirlpool LEC7858AZ1 ELECTRIC DRYER
Whirlpool LEC7858AZ2 ELECTRIC DRYER
Amana LEC80AW DRYER- ELE
Whirlpool LEC8858DQ0 ELECTRIC DRYER
Whirlpool LEC8858DQ1 ELECTRIC DRYER
Whirlpool LEC8858DZ0 ELECTRIC DRYER
Whirlpool LEC8858DZ1 ELECTRIC DRYER
Whirlpool LEC8858EQ0 ELECTRIC DRYER
Whirlpool LEC8858EQ1 DRYERS
Whirlpool LEC8858EQ2 ELECTRIC DRYER
Whirlpool LEC8858EZ0 ELECTRIC DRYER
Whirlpool LEC8858EZ1 DRYERS
Whirlpool LEC8858EZ2 ELECTRIC DRYER
Whirlpool LEC9000PW0 29" ELECTRIC DRYER
Whirlpool LEC9000PW1 29" ELECTRIC DRYER
Amana LEC90AW DRYER- ELE
Frigidaire LECR23EFE0 Frigidaire/refrigerator
Frigidaire LECR23EFE1 REFRIGERATOR
Frigidaire LECR23EFE2 REFRIGERATOR
Frigidaire LECR23EFE3 REFRIGERATOR
Amana LED20AW DRYER- ELE
Amana LED250 WASHER-TOP LOADING
Amana LED250 DRYER- ELE
Amana LED302 DRYER- ELE
Amana LED302 WASHER-TOP LOADING
Amana LED32AW DRYER- ELE
Amana LED450 WASHER-TOP LOADING
Amana LED450 DRYER- ELE
Amana LED502 DRYER- ELE
Amana LED57AW DRYER- ELE
Amana LED65AW DRYER- ELE
Amana LED850 WASHER-TOP LOADING
Amana LED850 DRYER- ELE
Amana LED902 DRYER- ELE
Amana LED950 WASHER-TOP LOADING
Amana LED950 DRYER- ELE
Frigidaire LEDB400FEE0 Frigidaire/dishwasher
Frigidaire LEDB500FEE0 Frigidaire Elements/dishwasher
Whirlpool LEE9848BQ0 ELECTRIC DRYER
Whirlpool LEE9848BQ1 ELECTRIC DRYER
Whirlpool LEE9848BQ2 ELECTRIC DRYER
Whirlpool LEE9848BZ0 ELECTRIC DRYER
Whirlpool LEE9848BZ1 ELECTRIC DRYER
Whirlpool LEE9848BZ2 ELECTRIC DRYER
Frigidaire LEEB30S9FEA Frigidaire/wall Oven
Frigidaire LEEB30T9FEA Frigidaire/wall Oven
Frigidaire LEEC30S9FEA Frigidaire/cooktop
Frigidaire LEEC36S9FEA Frigidaire/cooktop
Frigidaire LEEFM389FEA Frigidaire/electric Range
Frigidaire LEEFM389FEB Frigidaire/electric Range
  #2 (permalink)
Old 10-08-2016, 08:52 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
It sounds like the motor bearings are getting tight and overheating the motor. It has to cool down to restart. Run the dryer till it quits, then pull the power to it and see how hot the motor is.
There is a good video on this page.
Whirlpool 279827 Dryer Drive Motor - AppliancePartsPros.com
  #3 (permalink)
Old 10-29-2016, 01:54 PM
Junior Member
Default
Thanks for the reply ThatGuy,
Is this a common problem? The unit isn't very old and the motor sounds fine right up to when it stops. When I pull the clothes out after they have gone through 2 or three of these cycles they are very hot. I feel like everything is getting to a heat trip point that shuts the dryer down. I can see the heat coil cycle and it (the coil) turns completely off about 10 seconds before the motor stops.
  #4 (permalink)
Old 10-30-2016, 02:06 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
If its really hot in the dryer, this could cause the motor to overheat. There is a overheat thermal switch on the motor to protect it. If the motor gets too hot or pulls to many amps it will shutdown the motor.
The question is why is it so hot in there?
Have you checked and cleaned all of you vent out? Never use flexible plastic vent on a dryer. Its very dangerous.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
After 20 mins. dryer vibrates and stops bigcrash29 Dryer Repair 0 02-27-2012 05:22 PM
dryer runs for 10 mins then blows breaker anguar Dryer Repair 1 08-29-2011 06:05 AM
Dryer runs, heats, then shuts off 15 mins mafia007 Dryer Repair 0 06-23-2010 05:43 PM
Dryer runs for only 10 mins. garylcarico Dryer Repair 1 05-07-2009 04:51 AM
dryer runs for few mins then shuts down MJM Dishwasher Repair 7 07-30-2008 09:16 PM
