Discuss
No Heat? Help pls. Kenmore HE2
 in
Dryer Repair
Trying to troubleshoot my Kenmore HE2 Electric dryer. Dryer runs, but produces no heat. Inspected and cleaned exhaust, which was
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat? Help pls. Kenmore HE2
  #1 (permalink)
Old 09-27-2016, 09:02 PM
Junior Member
JPCyan is on a distinguished road
Question No Heat? Help pls. Kenmore HE2
Model Number: 110.86562500   Brand: Kenmore   Age: 5 - 10 years
Inspected and cleaned exhaust, which was only slightly dirty. I clean this every couple months. Cleaned interior/parts
With a digi meter, I checked input voltage at fuse box, outlet. 240v Tested OK
Tested continuity on thermal fuse on blower, High limit thermostat and fuse on element case and Heating element itself. All check OK with good continuity.
Is there any test I can perform on main control board? Should I order a board?
Any other ideas and tips would be much appreciated.
Thanks JPC
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 09-27-2016, 09:36 PM
Junior Member
Default
Thermistor WP8577274 on the exhaust tested at 11k ohms with multimeter at about 72f . Rated at 10k at 77f.
Hmmm? Am I missing something?
Expert Opinions welcome.
Last edited by JPCyan : 09-27-2016 at 10:26 PM. Reason: updating and correct part name
  #3 (permalink)
Old 09-28-2016, 07:30 PM
Junior Member
Default No one?
I pulled the main control board. Checked for obvious discoloration/ scorched components. Nothing apparent.
Cleaned the PCB and checked for cold solder joints or loose components. Still nothing obvious.
I'm beginning to lose my manhood here, as the wife is doubting my ability and threatening to buy a new one. NO!!
anyone? A lil help?
  #4 (permalink)
Old 09-29-2016, 05:01 AM
Senior Member
cbmserviceguy is on a distinguished road
Default
Fire the old girl up and trace power. First check is for 240 vac at the element. The voltage is divided when it goes thru the unit. One leg of 120 vac runs thru the t-stat/limit and the other goes thru the centrifical switch in the motor. If 240 isn't present at the element, shut everything off and unplug unit. Disconnect wires from element and then retest. Determine which wire going to the element has 120 vac. Work backwards on the dead leg until you find where it loses the power. Do you have a wiring diagram for the unit? It helps a lot in making short cuts obvious, such as testing the power out of the board to the element. Keep in mind that if the wires are connected at the heater and you try to test 120 vac, it will back feed thru the element and give you false readings. Let me know if there is anything else I can help with!
  #5 (permalink)
Old 09-29-2016, 09:49 AM
Junior Member
Default Thanks!
Your input is much appreciated cbmserviceguy.
I don't have a wiring diagram. I will try to locate one. If its available online , I'll find it. Was hoping for the simple quick fix, but this is never my luck.
I will perform testing as you described and see where it leads me. I was trying to avoid working on the unit hot (with power), but I am confident it should be no problem.
I am an electronics tech by trade, mostly low voltage dc (wired/wireless communications). However when I open up something I am not familiar with, it sometimes takes a knowledgeable nudge to point me in the right direction. Even if it is as obvious as tracing loss of voltage or basic troubleshooting steps.
Thanks again, I'll update when testing is complete.
  #6 (permalink)
Old 09-29-2016, 09:56 AM
Senior Member
Default
No problem. Feel free to post any questions or requests for further information as they come up. I'll help however I can. The wiring diagram is typically located behind the control panel or taped to the bottom of the lid. Good luck and keep us updated!
  #7 (permalink)
Old 09-29-2016, 01:54 PM
Junior Member
Default
Thanks for the heads up on the location of the diagram. Fortunately it is a troubleshooting/tech sheet as well.
I followed several steps including the self diagnostic feature. Testing components as needed.
I followed TEST #3 -HEATER TEST. I measured resistance from the thermal cutoff to the heater. 10 ohms-- CORRECT
The next step, #5 reads as follows
"If no open circuit detected, Measure the resistance between P14-3(red-white wire) and P14-6(red-white wire) at the machine control board"
"-> if 5-15k ohms are measured, replace the machine control electronics"
I measured approx. 12k ohms at wires while connected to PCB,
12k ohms on wires disconnected from PCB
open at PCB without wires
Just looking for verification that my tests of the wires, while connected or disconnected, are the correct readings to determine fault?
Thanks again JPC
  #8 (permalink)
Old 09-30-2016, 05:00 AM
Senior Member
Default
Sure sounds like it to me. Time to get a new board!
  #9 (permalink)
Old 10-01-2016, 04:28 PM
Junior Member
Default
Much thanks again cbm. Ordering a board. I might even try troubleshooting the defective one if I can find a schematic and get free time on the bench at work.
Of course it is one of the most expensive parts in the dryer, but much cheaper than a new dryer!
Thanks APP, forums, chat, techs and all here who contribute. Great site, Videos, and info. Most helpful.
I will update when repairs are complete, for anyone who needs reference in the future.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Gas Oven Wont Heat to pre heat or takes a long time rmcgove Oven Repair (including Ranges and Cooktops) 0 04-23-2014 03:05 PM
kenmore he3 gas no heat ronconpepsi Dryer Repair 0 07-01-2013 08:22 AM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Kenmore Model 110 76652500 kenmore no heat cgarza1 Dryer Repair 0 09-02-2010 02:09 PM
