Discuss
Whirlpool Roper Won't start!
 in
Dryer Repair
To preface: I had started and ran the dryer the night before I started having issues with it. It ran
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Roper Won't start!
  #1 (permalink)
Old 09-24-2016, 11:15 AM
Junior Member
seymop is on a distinguished road
Default Whirlpool Roper Won't start!
Brand: Whirlpool   Age: 5 - 10 years
To preface:
I had started and ran the dryer the night before I started having issues with it. It ran through a whole cycle and buzzed when it was finished. I tried to start it the following morning and nothing happened. No hot smells or anything.
When I push the start button, nothing happens. There are no buzzer sounds or any sort of noises like the motor trying to start. Dead silence.
Things I have tried:
I have tested the power to the dryer which is fine.
The power to and from the timer unit is also fine.
I have bypassed the door switch to see if that could have been the issue. That did nothing.
I unhooked the motor and tested that for continuity. I tested terminals 4 and 5 which came up with 1.7 Ohms (range was 2.4 - 3.6). I tested terminals 4 and 6 with the disc pushed in and came up with around 2.8 or so. Could the low Ohms reading between 4 and 5 mean a bad motor?
I tested the start switch for continuity and came up with 0.3 ohms with the switch pushed in.
Anyone have any idea what's going on with this thing?
  #2 (permalink)
Old 09-24-2016, 03:44 PM
Senior Member
brobriffin is on a distinguished road
Default
I can be exact with your model number. Vaguely it sounds as if your thermal fuse is blown.
  #3 (permalink)
Old 09-24-2016, 06:00 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Please post model number.
  #4 (permalink)
Old 09-24-2016, 08:16 PM
Junior Member
Default
Sorry.
RED4340SQ1
  #5 (permalink)
Old 09-25-2016, 06:53 AM
Senior Member
Default
Thank you.
Now check your thermal fuse. Your fuse should show continuity. If not then your exhaust temperature has exceeded 196 F and it is bad here is your part number.
Whirlpool WP3392519 Dryer Thermal Fuse - AppliancePartsPros.com
There is a video along with this link.
Also as Matt suggests in the video clean your entire vent system and ductwork, which may have been the cause for increase exhaust temperature.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Dryer Won't Start jfemal Dryer Repair 9 04-27-2014 06:58 AM
Roper (whirlpool) won't start. Tried all the usual problems. forstm Dryer Repair 3 08-21-2013 09:55 AM
Roper (Whirlpool) dryer won't start Quasimodo1234 Dryer Repair 7 10-22-2012 08:32 AM
Roper by Whirlpool Dryer Wont Start cjduke Dryer Repair 1 07-31-2011 03:34 AM
Roper won't start pauldavis101 Washer Repair 1 03-12-2010 06:09 PM
