This problem deals with a Frigidaire stacked washer/dryer combo EX841FS4 in order to replace the 2 position Temperature Selector switch.
The control panel on this model has an separate back panel to which all of the controls are screwed. My problem is trying to remove the front panel to gain access to the back panel which will allow me to also access the rear of the Timer Control in order to remove it's front knob.
I have removed all visible screws holding both the Front Panel and it's end caps.
