3 Pages123>
spelding
#1 Posted : Friday, September 16, 2016 5:48:12 AM(UTC)
spelding
Hi.
This site was instrumental in helping me to get my Whirlpool dryer heating again. I wound up replacing the hi limit thermostat and thermal fuse. Since I had the dryer apart, I also replaced the drum belt and the drum gasket. Cleaned it out well and voila, the dryer heated perfectly.
The only thing that did not work after putting everything back together was the timer, which honestly wasn't a big deal at all. That was about 6 months ago, and now the dryer isn't heating again. Is it possible the parts I replaced went bad, or could it be the heating element?
I spent almost $60.00 on the last repair, and even though that's probably more than the dryer is worth, it's in very clean, excellent condition, so I wouldn't mind having to spend an additional fifty bucks or so to get it heating again. Thanks.
brobriffin
#2 Posted : Wednesday, September 21, 2016 2:04:50 PM(UTC)
brobriffin
Man
United States
One reason that a dryer will fail in a relatively short time is due to poor air flow. This can be caused by clogged vent ducting and/or roof vent cap. It could also be a result of a kinked, crimped transition hose (the hose between the back of your dryer and the wall).
Your dryer needs to move approximately 120 cubic feet of air per minute to remove excess heat and water vapor. Most vent ducting systems are designed to allow 150 CFM through a 4 inch line.
If the restriction is severe enough the air doesn't flow from the heating element through the drum and out the exhaust causing the components to overheat.
Before you replace whatever has failed please check all of these items or you will be having failure after failure.
Manufacturers list in the owners manual frequency of dryer vent system cleaning, usually 1 to 2 years depending on usage.
Also be careful not to push the dryer to far back against the wall causing the transition hose to kink or crimp.
To answer your question it may be the thermal cut off, or the high limit thermostat, or the cycling thermostat or the heating element. You will need to perform a continuity check on each to see which is bad.
spelding
#3 Posted : Wednesday, September 21, 2016 5:11:57 PM(UTC)
spelding
Thanks for your reply brobriffin.
When I did the last repair I purchased a new vent hose. There is sufficient room so as to not cause any kinks or bends. I have never done a continuity test, so if you wouldn't mind, could you walk me through it like I was a ten year old.Lol.
Don't get me wrong, I am confident in my ability to be able to fix this. It's just that when I am in uncharted waters, I want to be precisely sure I am doing everything properly, and following suggestions and procedures. I guess my first move would be to purchase a continuity tester. How much does an entry level tester sufficient to get a proper reading, cost?
Thank you,
spelding
brobriffin
#4 Posted : Thursday, September 22, 2016 2:04:42 PM(UTC)
brobriffin
Man
United States
You can obtain an analog multimeter at one of the big box hardware stores for roughly 15 to 20 bucks.
Get back with us when you get one and we will guide you through a test.
Also I understand you have a new vent (transition) hose. Have you had the duct-work through the walls to the exterior of the home cleaned?
spelding
#5 Posted : Thursday, September 22, 2016 6:19:23 PM(UTC)
spelding
The dryer is located in a small laundry closet virtually against the exterior wall. As a result, the new ducting stretches about 2 get, from the back of the dryer to the connection on the exterior wall. The duct is metal ( think big metal slinky) and was recommended to use.
I actually went out today and purchased a dryer from Craigslist for 30.00 Although the ad said electric dryer, when I went to pick it up it had a gas connection and a 110 volt 3- prong plug. Trouble, I have a 220 volt outlet. What I'm looking for now I'd an adapter that I can plug the 110 volt plug into, with the other end a make sure 20 volt plug. That should work, correct. Reason I ask is that the dryer starts, the drum spins, but no heat. I assumed the gas connection provided the heat, while the 110 v provided the power to run the motor.
Don't seem to be having much luck with dryers lately. First, my dryer quite, then a friend of my niece gave us a dryer which didn't turn on at all, and now this.
Thinking about going back to the old standby; the clothesline!!! (Lol)
spelding
#6 Posted : Thursday, September 22, 2016 6:24:01 PM(UTC)
spelding
By the way, the dryer I bought was a Kenmore stackable unit. If I had a gas hookup in my laundry closet, I would just hook that up and be done with it.
brobriffin
#7 Posted : Friday, September 23, 2016 4:45:33 AM(UTC)
brobriffin
Man
United States
Sorry but you can not convert a gas dryer into a 220 electric heat dryer. IMPOSSIBLE! I can help but please do not attempt to plug a 110 machine into a 220 outlet.
Again the problem with your dryer is likely easy and cheap to repair. However it doesn't sound as if you have much experience with electronics. Please get a multimeter to locate the problem with your machine.
Try to sell that gas dryer it will do you no good.
spelding
#8 Posted : Friday, September 23, 2016 8:27:51 AM(UTC)
spelding
Thanks. I did a few Google searches to that effect. Yeah, we're going to sell the washer dryer stackable unit. I currently have a Southwire non- contact AC voltage detector, and surprise, I found a Southwire continuity tester. Don't even remember buying it. The tester I have looks like a fat pen. One end has a metal point, the other end has a black wire ending in a rubber sheathed alligator clip. Will either of those suffice? Is a multimeter different from a continuity tester? Thanks.
I appreciate your input. Great thing about sites like this is I get more knowledge about how to fix stuff from helpful individuals like you.
Like I said before, I have the confidence and the desire to learn how to do things. I don't know a heck of alot about electricity in detail, but I have rewired single gang boxes, installed GFCI outlets and the like. Over the years as a homeowner, I also have laid tile, done some plumbing work, sheet rock and plaster, furniture refinishing.
Gives you a good feeling knowing you did stuff by yourself and saving some money to boot.
brobriffin
#9 Posted : Friday, September 23, 2016 10:09:40 AM(UTC)
brobriffin
Man
United States
Good for you! We all can gain experience when we DIY. The continuity tester is exactly what we need....
Ok Lets do some testing. First please unplug your dryer from the 220/240v outlet and move it out to where you can access the back.
Next you will need to remove the back cover consisting of 9 screws using a 1/4 inch nut driver. One of those screws hold the terminal block (incoming power) cover. After removing the back cover you will see two different sides. One is the heater can, it's on the right as you look at it from behind. The other side is the exhaust. On the heater side you will find three things that need to be checked.
1. The heating element, which will be the bottom most two connections. Place your continuity tester on one connection and the alligator clip on the other. This should have a positive result. If not the heating element is bad.
2. The high limit thermostat, which is just above the heating element. Check for continuity across its two terminals. Again with a positive result it is good.
3. There is a high limit thermal cutoff toward the top of the heating can. It is smaller in diameter than the thermostat you just checked. Check for continuity across its two terminals. Again with a positive result it is good.
Now if they are all good then we switch over to the exhaust side. Here you will see two items. We need to check both of these as well.
1. Thermal fuse, which is the white plastic looking thing rectangular shaped. Test for continuity across it's terminals. I Believe you will find it is good or else the unit would not start up at all.
2. Cycling thermostat, This will be a four pronged thermostat with two large red wires and two smaller wires. We will only check for continuity across the two larger terminals with the red wires. If you get a positive result then it is ok.
Perform all of these checks and give us your findings.
spelding
#10 Posted : Friday, September 23, 2016 11:12:11 AM(UTC)
spelding
Thanks brobriffin. I'll be out visiting on Saturday, Sunday is church and football, lol, so I'll probably get to it on Monday. I'll let you know.
Whirlpool Dryer won't heat (Dryer Repair)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
Whirlpool dryer won't heat during auto cycle (Dryer Repair)
by Pdcrull 9/7/2014 8:52:29 PM(UTC)
Whirlpool Dryer Won't Heat (Dryer Repair)
by rebecca0101 9/4/2014 10:46:27 AM(UTC)
Whirlpool dryer won't heat (Dryer Repair)
by jev 12/7/2011 5:34:31 PM(UTC)
by Rans 2/12/2010 11:52:28 AM(UTC)
Whirlpool Dryer won't heat up (Dryer Repair)
by jmrobeck 9/2/2008 10:59:58 AM(UTC)
by haddy 8/14/2008 7:44:34 PM(UTC)
3 Pages123>
