I checked the components and my dryer isn't heating at all due to a bad igniter. My problem is figuring out how to get the igniter out. All the videos make the igniter look easy to replace, but those igniters in the videos are easily reached.
The performa hides the igniter in behind the gas assembly and looks impossible to get to without removing the assembly. How do I remove the assembly, or is there something I'm missing that would make this an easier job?
Thanks for any help.
