| » dryer wont heat up? |
Model Number: leq9030pqo Brand: Whirlpool Age: 1 - 5 years
my dryer hont heat up. it turns on but therte is no heat!
Related Models |
Replacement parts for WHIRLPOOL LEQ9030PQ0 | AppliancePartsPros.com Here is a wiring diagram http://www.servicematters.com/docs/w...%208528187.pdf First try flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker. Better yet measure it with a meter should be 240 volts. On this unit if the timer advances in timed dry, you have the 240 as the timer motor uses 240. Next unplug the unit and check the heating element, the thermal cut-off, the hi-limit thermostat and the operating thermostat. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use.
__________________
| Display Modes | |
| my dryer wont heat | beer2300 | Dryer Repair | 1 | 09-04-2009 12:32 PM |
| clothes dryer wont heat timer wont work | tampee | Dryer Repair | 2 | 01-17-2009 10:53 AM |
| Gas dryer wont heat up | yertle11 | Dryer Repair | 6 | 01-09-2009 03:17 PM |
| Timer wont advance and dryer wont heat | awatt26 | Dryer Repair | 2 | 06-20-2008 10:43 PM |
| Dryer wont heat | retcsgt | Dryer Repair | 0 | 10-29-2007 04:51 AM |
