Wumford
#1 Posted : Saturday, August 13, 2016 12:43:25 PM(UTC)
Wumford
Im looking for a wiring diagram for my amana dlg330raw control panel.
I recently took apart my Amana dlg330raw dryer to replace a belt, when I got it back together it flips the breaker as soon as its plugged in.
I'm assuming I switched up a wire somewhere in the control panel because those are the only wires i took off. I double checked all the other connections and everythings good there.
Any help would be greatly appreciated
brobriffin
#2 Posted : Wednesday, August 17, 2016 7:14:38 AM(UTC)
brobriffin
Man
United States
Whirlpool R0000409 Kit, Dryer Timer - AppliancePartsPros.com
Look at the 3rd picture, also on your timer you should see letters that correspond with the correct wire colors.
If the wires are on correctly did you happen to pinch a wire like the door switch hot lead when reassembling?
