Discuss
Dryer wont start only buzzing sound for 5 seconnds
 in
Dryer Repair
I have a whirpool dryer, don't know model number. It was working fine all day and then when we changed
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer wont start only buzzing sound for 5 seconnds
  #1 (permalink)
Old 11-01-2009, 02:44 PM
Junior Member
Kopchak1 is on a distinguished road
Default Dryer wont start only buzzing sound for 5 seconnds
Brand: Whirlpool   Age: 1 - 5 years
I have a whirpool dryer, don't know model number. It was working fine all day and then when we changed loads it would not turn on. When I push the start button all I hear is a buzzing sound for about 5 seconds then it clicks off. There is also a bad smell like something burning coming from the back. I have looked up on the internet and sounds like a thermal fuse or heat element issue how do I fix it? Where can I find the model number also.
Ads By Google
  #2 (permalink)
Old 11-02-2009, 01:36 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Sounds like the motor is not starting, it buzzes then overheats and it's internal thermal protect trips.
Try turning the drum by hand, it should turn fairly easily. It may be jammed, stalling the motor.
If OK
This may take two people
Open the door and hold the door switch closed.
Push the push-to-start switch.
Manually turn the drum in the correct direction.
Watch your knuckles.
If it starts up your motor probably needs replacing.
__________________
  #3 (permalink)
Old 05-04-2011, 07:37 PM
Junior Member
AntonB is on a distinguished road
Default
I'm having the same problem, and turning the drum by hand gets the motor going again...but I put in a new motor about 4 months ago, and it was running great until yesterday. So something seems to be causing the motor to go bad. Any idea as to why that could happen?
  #4 (permalink)
Old 05-05-2011, 02:38 AM
Senior Expert
APP Volunteer
Default
Could be a number of things.
1. Try turning the drum in the correct direction by hand. It should turn fairly easily. You may want to try this on a couple other units to get a feel for it.
This should check whether there is too much drag on the drum which is overloading the motor.
2. Check your power.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Low power on the motor side (usually L1 to Neutral) can cause motor overheating and eventual failure.
3. When the drum is not turning do you have heat?
Do not let it run too long like this as you could blow a thermal fuse.
If there is heat I would check the centrifugal switch mechanism on the motor.
Could be it is clogged with lint or for some reason it is not returning to the at rest position.
The motor has 2 centrifugal switches. They close when the motor gets close to operating speed so if you have heat it means that the heater centrifugal switch is closed when the motor is not rotating. This is important because the other switch switches in/out the motor's start winding so perhaps the motor is trying to start without the start winding in circuit.
4. Check the wiring to the motor.
5. Could be just a defective motor.
__________________
  #5 (permalink)
Old 01-14-2012, 07:20 PM
Junior Member
Castrol is on a distinguished road
Default whrirpool dryer- Gas model LGT7646EQ2
Dyer will start easily when cold and will run and with heat on for 10 to 15 minutes, then it will stop. After 10 to 15 minutes, you will hear a buzzing sound like trying to start again; sometimes it will turn and run
again but most of the time it won't.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Buzzing sound followed by a click and the sound goes away. mpwizard22 Refrigerator & Freezer Repair 4 02-23-2010 11:20 AM
Dryer does not start, makes no sound Pennell Dryer Repair 1 11-13-2009 03:45 AM
Dryer won't start but hear a buzzing noise Anthony M. Reyes Dryer Repair 5 07-13-2009 05:44 PM
Dryer won't start...buzz sound RockyRocks Dryer Repair 1 06-03-2009 06:27 PM
Dryer makes a buzzing sound when trying to start? romeo79 Dryer Repair 1 04-26-2009 05:39 AM
