Discuss
Dryer won't heat
 in
Dryer Repair
My neighbor has an old stack unit from Maytag. Just recently it quit heating. I recently replaced the Gas hot
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't heat
  #1 (permalink)
Old 02-20-2008, 12:49 PM
Junior Member
kw48116 is on a distinguished road
Default Dryer won't heat
Model Number: LSG1000   Brand: Maytag   Age: More than 10 years
My neighbor has an old stack unit from Maytag. Just recently it quit heating. I recently replaced the Gas hot water heater and turned off the main gas supply. It hasn't produced heat since. I know that she has hot water and the furnace is also working so it isn't a gas supply issue. In looking at posts on this forum, it does not appear that this dryer has a pilot light. Where do I start to figure out the problem?
Thanks for the help,
Ads By Google
Related Models
Maytag LSG1000 Stacked Laundry - Gas
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W Stacked Laundry - Gas
Jenn-Air LSG2704W Stacked Laundry - Gas
Maytag LSG7800 Stacked Laundry - Gas
Maytag LSG7800AAE Stacked Laundry - Gas
Maytag LSG7800AAL Stacked Laundry - Gas
Maytag LSG7800AAW Stacked Laundry - Gas
Maytag LSG7800ABE Stacked Laundry - Gas
Maytag LSG7800ABL Stacked Laundry - Gas
Maytag LSG7800ABW Stacked Laundry - Gas
Maytag LSG7804AAE Stacked Laundry - Gas
Maytag LSG7804AAL Stacked Laundry - Gas
Maytag LSG7804AAM Stacked Laundry - Gas
Maytag LSG7804ABE Stacked Laundry - Gas
Maytag LSG7804ABL Stacked Laundry - Gas
Maytag LSG7804ABM Stacked Laundry - Gas
Maytag LSG7806AAE Stacked Laundry - Gas
Maytag LSG7806AAM Stacked Laundry - Gas
Maytag LSG7806AAQ Stacked Laundry - Gas
Maytag LSG7806ABE Stacked Laundry - Gas
Maytag LSG7806ABM Stacked Laundry - Gas
Maytag LSG7806ABQ Stacked Laundry - Gas
Maytag LSG9900 Stacked Laundry - Gas
Maytag LSG9900AAE Stacked Laundry - Gas
Maytag LSG9900AAL Stacked Laundry - Gas
Maytag LSG9900AAW Stacked Laundry - Gas
Maytag LSG9900ABE Stacked Laundry - Gas
Maytag LSG9900ABL Stacked Laundry - Gas
Maytag LSG9900ABW Stacked Laundry - Gas
Maytag LSG9904AAE Stacked Laundry - Gas
Maytag LSG9904AAL Stacked Laundry - Gas
Maytag LSG9904AAM Stacked Laundry - Gas
Whirlpool LSH9264HQ0
Whirlpool LSL9244EQ0
Whirlpool LSL9244EZ0
Whirlpool LSL9345EQ0
Whirlpool LSL9345EQ1
Whirlpool LSL9345EZ0
Whirlpool LSL9345EZ1
Whirlpool LSL9355DQ0
Whirlpool LSL9355EQ0
Whirlpool LSL9355EQ1
Whirlpool LSN1000HQ0
Whirlpool LSN1000HZ0
Whirlpool LSN1000JQ0
Whirlpool LSN1000JQ1
Whirlpool LSN1000JT0
Whirlpool LSN1000JT1
Whirlpool LSN1000KQ0
Whirlpool LSN1000KT0
Whirlpool LSN1000LG0
Whirlpool LSN1000LG1 Automatic Washer
Whirlpool LSN1000LG2 Automatic Washer
Whirlpool LSN1000LG3 Automatic Washer
Whirlpool LSN1000LW0
Whirlpool LSN1000LW1 Automatic Washer
Whirlpool LSN1000LW2 Automatic Washer
Whirlpool LSN1000LW3 Automatic Washer
Whirlpool LSN1000PQ0 Automatic Washer
Whirlpool LSN1000PQ1 Automatic Washer
Whirlpool LSN1000PQ2 Automatic Washer
Whirlpool LSN1000PQ3 Automatic Washer
Whirlpool LSN2000JQ0
Whirlpool LSN2000JQ1
Whirlpool LSN2000JQ2
Whirlpool LSN2000JT0
Whirlpool LSN2000JT1
Whirlpool LSN2000JT2
Whirlpool LSN2000LG0
Whirlpool LSN2000LG1 Automatic Washer
Whirlpool LSN2000LW0
Whirlpool LSN2000LW1 Automatic Washer
Whirlpool LSN2000PG0 Automatic Washer
Whirlpool LSN2000PG1 Automatic Washer
Whirlpool LSN2000PG2 Automatic Washer
Whirlpool LSN2000PG3 Automatic Washer
Whirlpool LSN2000PG4 Automatic Washer
Whirlpool LSN2000PW0 Automatic Washer
Whirlpool LSN2000PW1 Automatic Washer
Whirlpool LSN2000PW2 Automatic Washer
Whirlpool LSN2000PW3 Automatic Washer
Whirlpool LSN2000PW4 Automatic Washer
Whirlpool LSN3000PG0 Automatic Washer
Whirlpool LSN3000PG1 Automatic Washer
Whirlpool LSN3000PG2 Automatic Washer
Whirlpool LSN3000PG3 Automatic Washer
Whirlpool LSN3000PG4 Automatic Washer
Whirlpool LSN3000PW0 Automatic Washer
Whirlpool LSN3000PW1 Automatic Washer
Whirlpool LSN3000PW2 Automatic Washer
Whirlpool LSN3000PW3 Automatic Washer
Whirlpool LSN3000PW4 Automatic Washer
Whirlpool LSN7233BN0
Whirlpool LSN7233BN1
Whirlpool LSN7233BQ0
Whirlpool LSN7233BQ1
Whirlpool LSN7233BW0
Whirlpool LSN7233BW1
Whirlpool LSN7233DQ0
Whirlpool LSN7233DW0
Whirlpool LSN8244AN0
Whirlpool LSN8244AQ0
Whirlpool LSN8244AW0
Whirlpool LSN8244BN0
Whirlpool LSN8244BQ0
Whirlpool LSN8244BW0
Whirlpool LSP6244AG0
Whirlpool LSP6244AN0
Whirlpool LSP6244AW0
Whirlpool LSP6244BG0
Whirlpool LSP6244BN0
Whirlpool LSP6244BW0
Whirlpool LSP8244BG0
Whirlpool LSP8244BG1
Whirlpool LSP8244BN0
Whirlpool LSP8244BN1
Whirlpool LSP8244BW0
Whirlpool LSP8244BW1
Whirlpool LSP8245AN0
  #2 (permalink)
Old 02-21-2008, 12:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would check is the gas supply to the unit.
There is a separate gas shut off valve behind the dryer and another shut off valve behind the access panel (#14 on the cabinet break down diagram).
With the access panel removed, start the dryer and see if the igniter glows.
If it does not, unplug the igniter and check for 120V coming to the igniter when the control calls for heat.
If there is 120V then check the igniter and the flame sensor (#9 on the heater assembly break down diagram) for continuity.
Replace the part with the open circuit.
If there is no 120V then the troubleshooting has to be done according to the wiring diagram which suppose to be on the inner side of the access panel or behind the washer front panel.
Unfortunately I'm not able to find the wiring diagram for this model on line.
- The part number for the igniter is AP3109449
- The part number for the flame sensor is AP2910747
Here are the break down diagrams for the Maytag laundry center Model LSG1000
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-25-2008, 09:34 AM
Junior Member
Default Thank you nd another question
Gene,
Thanks for the help
It turned out to be the gas shut off.
For whatever reason she had turned off the dryer shutoff valve when the HW heater died and forgot that she did that.
Sooo simple.
While I was there she mentioned that sometimes the washer wouldn't spin dry the clothes well. THANKS FOR ALL THE LINKS. I replaced the belts to the tub and the pump. With the dryer working again she has washed several loads of clothes and some still have not been well spun dried. If she repeats the cycle all is good. I didn't see any tensioning mechanism for the pump belt. SO... again I am at loss as to where to start
Thanks again for all your help
Keith
  #4 (permalink)
Old 02-25-2008, 11:12 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Keith,
One of the most common cause for such problem is not balanced load.
When it happened the washer will never go on full speed during the spin cycle.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
