| » Electric Dryer NO HEAT |
Model Number: 110.60942990 Brand: Kenmore Age: 5 - 10 years
My 27 inch model 110.60942990 Kenmore Elite dryer no longer generates any heat. All other functions seem to work properly. I can't see how to access the heating element. Need a diagram and any troubleshooting steps would be greatly appreciated.
Related Models |
Access this dryer's stuff by dropping the kick plate. Use a putty knife to release the springclips atop dat kick plate. Note: you cannot access this dryer from the rear
A manual that features this type dryer. page 15 shows an illustration of how to remove dat toe panel all propah. Last edited by SublimeMasterJW : 11-01-2009 at 01:05 PM. |
You may want to check that you have 240 volts.
Turn the breaker off/on a couple times. Sometimes you can loose half the line without tripping the breaker and the heater requires the full 240. Better yet measure it with a meter.
__________________
If dryer is getting 240v check Thermal fuse and Thermal Cutoff (for continuity) and heating element also for continuity. One or all may need replaced (any of those that do not show continuity go ahead and replace). Fuses and Heating elem usually blow out because of restricted airflow in vent hose.
| Display Modes | |
| electric dryer won't heat | newshawk | Dryer Repair | 3 | 04-15-2009 03:30 AM |
| Electric Dryer will not heat | Shep | Dryer Repair | 1 | 04-14-2009 01:40 PM |
| Electric dryer some heat not much | hankw | Dryer Repair | 6 | 12-30-2008 02:40 PM |
| Electric Dryer will not heat | JOYCENAPIER | Dryer Repair | 3 | 10-15-2008 05:25 AM |
| Electric Dryer does not heat | rhonnie35 | Dryer Repair | 1 | 05-25-2008 08:47 PM |
