norbreym28
#1 Posted : Saturday, July 16, 2016 8:29:04 AM(UTC)
norbreym28
My dryer won't start when you push start it just beeps and I hear a popping noise where the old one blew (where the red and black wire plugs in at thought the control board was bad but when I replaced it does the same thing because I seen a burn Mark on the protection shield when I took the old one off. I bought a remanufactured part online could it be a bad part or something else?
brobriffin
#2 Posted : Friday, July 22, 2016 6:30:48 AM(UTC)
brobriffin
Man
United States
It sounds like you may have bad wiring or connectors. The popping sound may be arcing across an opening in the wire / connector. Especially if you've seen burn marks on the protection shield. If this is the case I recommend replacing the wiring harness Whirlpool WP8576530 Harns-Wire - AppliancePartsPros.com
Resist the temptation to repair the wiring, a bad patch job can possibly lead to a short circuit or worse a fire.
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool Duet Dryer Drum turning difficulty (Dryer Repair)
by DWMalcolm 2/6/2022 12:41:34 PM(UTC)
Whirlpool duet dryer issue (Dryer Repair)
by Wes13 12/15/2021 3:54:09 PM(UTC)
Duet Mod# GE9200LW1 Whirlpool Duet dryer (Dryer Repair)
by Guest 11/17/2021 6:59:07 PM(UTC)
Whirlpool duet dryer making clicking noise (Dryer Repair)
by Ctiong916 4/23/2021 9:00:11 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Whirlpool Duet Dryer - WED9200SQ0 - Thermal Fuse (Dryer Repair)
by cjmatthes 1/17/2020 2:09:48 PM(UTC)
Whirlpool Duet dryer - no heat (Dryer Repair)
by colino 3/19/2018 10:56:53 AM(UTC)
Whirlpool Duet Dryer Squeaks / Squeals (Dryer Repair)
by RickG375 1/5/2017 7:08:55 PM(UTC)
Whirlpool Duet Dryer Squeaks/Squeals At Start Up (Dryer Repair)
by damianr418 11/5/2016 6:53:54 PM(UTC)
Whirlpool Duet Dryer Grinding Sound (Dryer Repair)
by mintken 10/16/2016 8:31:42 AM(UTC)
Whirlpool Duet Dryer won't start (Dryer Repair)
by berthettah 7/21/2016 10:10:39 AM(UTC)
Whirlpool Duet Dryer F02 and F70 codes (Dryer Repair)
by esnyder 7/6/2016 1:18:43 PM(UTC)
Whirlpool Duet Dryer Error Code f25 (Dryer Repair)
by wwwhitley 10/30/2015 12:09:40 PM(UTC)
Reset F 25 code on whirlpool duet dryer? (Dryer Repair)
by GreggyG 10/9/2015 7:53:30 PM(UTC)
