I just replaced the motor with exact replacement. The first time the dryer worked correct. Now when you close the door the motor tries to start, before you push the start button. It will not go unless you turn the drum by hand then works until clothes are dry. Once in a while it works correct. It will start and run IF when you close the door, it does not try and start. Then push the start button and it runs perfect. I am thinking maybe the timer? It is like the motor has a start relay that is not working because the timer is not working proper.
Thanks in advance, Dan
