Rexy
#1 Posted : Sunday, June 26, 2016 4:21:55 PM(UTC)
Rexy
I replaced the drum rollers due to squeeking. Now my dryer will not heat. What did I do wrong?
Only thing I had different with was disconnecting the moisture sensor. Could I have damaged this and caused the dryer to stop heating?
thorning
#2 Posted : Sunday, July 3, 2016 12:37:03 PM(UTC)
thorning
Bypass it with a jumper wire temporarily to rule the sensor out. you may have to take the front cover off to be able to get at the wire connections.
Appliance Mountain
#3 Posted : Sunday, July 3, 2016 1:15:28 PM(UTC)
Appliance Mountain
If you have bypassed the the moisture sensor you should check the heating element.
