mrdon
#1 Posted : Friday, April 15, 2016 1:57:37 PM(UTC)
mrdon
When I press the start button the dryer will turn on, but when it is released it turn off. If I hold down the button the drum will turn and the burner will kick on and will stop when I let it go. Any suggestions on what I should check?
Appliance Medics
#2 Posted : Saturday, April 16, 2016 9:01:40 AM(UTC)
Appliance Medics
This repair can actually be a little tricky. Sometimes (rarely) you can get away with a bad push to start switch. More commonly i find in the GE's it is a bad centrifugal switch in the motor. to test it of course your going to need a schematic or wiring diagram. occasionally you can see the spring loaded switch broken apart and pieces laying in the bottom of the dryer. good luck
no noise when push buttons on icemaker to dispense ice (Refrigerator & Freezer Repair)
by Messenger12 2/27/2023 3:06:18 AM(UTC)
Push button light switch broken (Oven Repair (including Ranges and Cooktops))
by b3853r 2/24/2022 12:40:32 PM(UTC)
push button (Dryer Repair)
by lanipola 1/20/2016 3:31:19 PM(UTC)
Dryer will not start up when I push button. (Dryer Repair)
by T0001ds 3/26/2010 10:47:56 AM(UTC)
push button panel problem (Dishwasher Repair)
by hudson 3/7/2010 7:20:17 AM(UTC)
How do I remove the push button oven light switch? (Oven Repair (including Ranges and Cooktops))
by audiacommike 2/9/2010 4:31:14 PM(UTC)
Push Button +spring Popped Out Of Handle (Microwave Repair)
by rgen 12/1/2009 1:22:34 PM(UTC)
Push Button Electronics on Ice / Water Dispenser Not Working (Refrigerator & Freezer Repair)
by JNN 10/26/2009 6:44:34 AM(UTC)
push button key pad to select ice / water (Refrigerator & Freezer Repair)
by Colin Twedt 6/16/2009 7:04:27 PM(UTC)
Push button for Door broken (again) (Microwave Repair)
by cblack 7/3/2008 9:55:14 AM(UTC)
Some Cotrol Panel push buttons do not work (Dishwasher Repair)
by MartinG 1/7/2008 10:53:52 AM(UTC)
