Greetings,
Motor runs, but no heat. Have replaced flame sensor (had no continuity) and gas valve coils (just because) with parts from your website. Ignitor has continuity as do both thermostats and the thermal fuse. My analog multimeter has only a x10 and x1K scales for measuring resistance. Do I need a more sensitive meter to detect variation? Or could it be that the ignitor is bad anyway, even though it is closed? Perhaps the timer and/or temp selector? (btw, I have no diagram to consult for testing either of those)
Thanks in advance for your time and consideration.
Brian
