Working on a GE dryer replaced MCB, terminal connector on board to Element was fried. all other terminals check fine. After replacing board I have no display. I have 120v feed to power in connector at board and 240 volts at connection. I suspect the Display board is bad. Other problem I have there are only 2 wires out of the connector to the elements yet the plug has 4. I connected the wires to the 2 outside terminals as there is no new harness available for the unit. My concern is what is the voltage to the display board suppose to be. Any help would be appreciated. Bill
