galerian
#1 Posted : Wednesday, January 6, 2016 8:52:13 AM(UTC)
galerian
I have a Whirlpool dryer that is over 28 years old. The model no. is LG5801XSW0.
It hums while the start knob is being pushed but doesn't start. I opened it up and tested the thermal fuse, start/door switches for continuity, all of which passed.
Then I tried pushing the start knob again and after humming for about 2 seconds, the dryer started again. So I reassembled the duct and the back panel, but now it won't start again. I held the start knob down and it stopped humming after a while, followed by a burnt smell. I waited about half an hour after that and tried pressing the knob again and it hummed but the dryer doesn't start.
What should I do next?
#2 Posted : Thursday, January 7, 2016 1:24:02 AM(UTC)
Try turning the drum manually in the correct direction.
It should turn fairly easily.
You may want to try this on a couple other units to get a feel for it.
If it is hard to turn then it is a drum mounting problem.
If it turns OK the odds are that you need a new motor.
I would check that the motor is clean as dust/dirt can clog up it's centrifugal mechanism.
Maytag Dryer hums, won't start. (Dryer Repair)
by jal3866 4/29/2012 9:35:59 AM(UTC)
Dryer hums, won't start (Dryer Repair)
by spearmint 8/14/2010 5:33:01 AM(UTC)
