haymon
#1 Posted : Tuesday, January 5, 2016 5:47:24 PM(UTC)
haymon
I have test all the fuses, all test good. Change the timer and still no heat.
Bobbi7007
#2 Posted : Tuesday, January 5, 2016 6:17:25 PM(UTC)
Bobbi7007
Have you checked the heating element? If that is broken, it will need to be replaced.
#3 Posted : Wednesday, January 6, 2016 1:43:29 AM(UTC)
A model number would be useful.
Find your model number - AppliancePartsPros.com
Start by checking the power.
The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
Admiral Dryer won't heat (Dryer Repair)
by MarkMLP 11/12/2014 6:25:55 AM(UTC)
