mdunlavy
#1 Posted : Tuesday, November 24, 2015 5:29:40 PM(UTC)
mdunlavy
whirlpool dryer starts and the drum turns but no heat to clothes. runs thru any cycle just no heat.
any ideas?
#2 Posted : Wednesday, November 25, 2015 7:42:06 AM(UTC)
Parts for Whirlpool LEQ9858PW0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Could be a number of things but I would start with the power.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If OK, unplug the unit and check the following with a meter:
Heater - 8 to 12 ohms
Thermal cutoff - 0 ohms
HiLimit Thermostat - 0 ohms
Operating Thermostat - 0 ohms
LEQ1442ES0 dryer: Drum Turns No Heat (Dryer Repair)
by beachgal59 2/8/2014 6:44:15 PM(UTC)
