hitmehhh
#1 Posted : Friday, November 20, 2015 5:07:53 AM(UTC)
hitmehhh
Dryer make a low pitched squealing noise when it first starts for about 20 seconds. Rear bearing is fine. Changed rear bearing sleeve. Changed front drum glides maybe a couple of years ago. Still getting noise sometimes only for 5 or 10 seconds on startup. Could the belt be worn and slipping when it first starts?
#2 Posted : Saturday, November 21, 2015 1:53:30 AM(UTC)
You will have to open it up to see what the problem is.
I doubt it is the belt.
Could be that the drum glides are gone again. Also check the idler wheel.
May even be the motor bearings are going.
hitmehhh
#3 Posted : Wednesday, November 25, 2015 5:38:59 AM(UTC)
hitmehhh
Opened it back up to check again. As the idler wheel was spinning the arm it is attached to was vibrating. I think the wheel hub was worn a lttle and not spinning smoothly. Changed it and seems to have done the trick
Samsung dryer noise (Dryer Repair)
by Guest 5/31/2021 10:07:46 AM(UTC)
Dryer Noise (Dryer Repair)
by johna56 11/2/2017 1:49:28 PM(UTC)
Maytag dryer noise (Dryer Repair)
by Cmjb13 9/7/2017 7:20:37 PM(UTC)
by hitmehhh 10/7/2016 5:35:15 AM(UTC)
Plz help. affinity dryer noise. (Dryer Repair)
by JHX 4/8/2016 11:42:59 AM(UTC)
Maytag Dryer Noise (Dryer Repair)
by azure012 7/11/2014 6:41:40 AM(UTC)
Dryer noise (Dryer Repair)
by jayjay19 1/3/2012 11:15:39 AM(UTC)
by hoan 12/30/2011 1:19:14 PM(UTC)
by Dan2175 12/21/2011 6:30:18 PM(UTC)
by wesw 11/5/2011 6:49:55 AM(UTC)
Elec Dryer Noise (Dryer Repair)
by mstickma 7/11/2011 9:12:54 AM(UTC)
by lmckelvy 11/9/2010 1:19:54 PM(UTC)
Frigidaire Gallery Dryer Noise (Dryer Repair)
by c24miller 10/15/2010 11:50:54 AM(UTC)
kenmore dryer noise (Dryer Repair)
by nobel5601 9/22/2010 1:34:49 PM(UTC)
by reecemj 5/31/2010 6:29:09 PM(UTC)
