serial 196981 xp series 07 Dryer motor runs. timer advances. got 220v to dryer. heater element is ok and not shorted to ground. thermal fuse has continuity. cycling thermostat has two leads on the left and one on the right. farthest one out on left to right one has continuity,the other one to the right one is open. checked it to ground and got1700 ohms resistance. thermal cut off has continuity, door switch also is good. any idea why no heat. also ducts are clear
