At my wits end trying to troubleshoot this dryer.. First the wrinkle guard stopped working, then the moisture setting stopped working and now timed dry. The dial advances on all during the cycle but I have no heat. Every once in a while I will get heat in timed dry but not very often at all. I have checked the thermal cut off and thermostat which all read 000 on my meter but I do get the beep so I am not sure if I am even doing it correctly. Checked the heating element and this I did get a reading of 12.0. I also did the same for the timer, started with it off and then tried each setting, just get a 1 on the left side of my meter and no beep or buzzing sound. Thinking its the timer but curious if this can cause the dryer to no heat? I have heard that the timer is actually what activates the heating element. Thoughts or help appreciated..
Thanks!
PS: I have not tested voltage at the outlet, but that is way out of my league...
