My maytag stack dryer wont heat. I check lint /vent and its clear of lint and air flow is good from outside (I also cleaned all old lint dirt including outside while I was checking just to start fresh). I called and ordered an ignitor (#4391996 ) part and valve coil ( #279834) so im hoping this does the trick, stay tune because I will need your help. Any further suggestions are appreciated if this dont work. Thank You.
