autoglassguy
#1 Posted : Tuesday, September 29, 2015 9:17:18 AM(UTC)
autoglassguy
My Samsung dryer does not heat and shows no error code. The dryer continues running even after pushing the power button to turn it off. It will stop running if you open the door but as soon as the door is shut it starts again with no display or lights whatsoever on the panel.
jhself
#2 Posted : Saturday, October 24, 2015 7:30:22 AM(UTC)
jhself
I have the same issue, what did you find wrong with yours?
Kimber350
#3 Posted : Thursday, August 18, 2016 1:49:38 PM(UTC)
Kimber350
What did you end up doing to fix your dryer?
Kimber350
#4 Posted : Thursday, August 18, 2016 1:50:26 PM(UTC)
Kimber350
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
samsung dryer Dv48H (Dryer Repair)
by Guest 2/27/2024 6:11:07 PM(UTC)
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
Samsung Dryer Test Mode (Dryer Repair)
by stanw 8/8/2023 2:36:51 PM(UTC)
Samsung Dryer possibly in flood throwing HC code (Dryer Repair)
by QuickPuppy 2/16/2023 7:41:27 AM(UTC)
Samsung dryer starts but won't turn drum or heat (Dryer Repair)
by coach_hall_42 1/22/2023 1:39:56 PM(UTC)
Samsung dryer stuck in continuous cycle (Dryer Repair)
by Guest 8/26/2022 6:18:39 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
Runs 3Min Stops-OR-Runs & Doesn't heat Samsung Dryer DV42H5000EW/A3-0000 (Dryer Repair)
by Guest 2/18/2022 11:57:14 AM(UTC)
Samsung dryer conversion to 50hz (Dryer Repair)
by Hlaudio 1/13/2022 2:57:31 AM(UTC)
Samsung dryer DV42H5200 still not heating after replacing all components (Dryer Repair)
by Guest 1/9/2022 11:26:52 AM(UTC)
Samsung Dryer HE error (Dryer Repair)
by hoagieh 10/23/2021 1:17:45 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
Samsung Dryer Error Code "HE" (Dryer Repair)
by czechmka 7/7/2021 11:01:22 AM(UTC)
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
