Discuss
Maytag Performa Electric Dryer No Heat
 in
Dryer Repair
#1 I cannot figure out how to get inside the dryer to do any work or check connections. I believe
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Performa Electric Dryer No Heat
  #1 (permalink)
Old 10-29-2009, 03:59 PM
linktlife linktlife is offline
Junior Member
linktlife is on a distinguished road
Default Maytag Performa Electric Dryer No Heat
Model Number: PYE2000AYW   Brand: Maytag   Age: More than 10 years
#1 I cannot figure out how to get inside the dryer to do any work or check connections. I believe it opens from the front somehow (sure hope so!) Help!!
#2 Dryer seems to be operating normally, but no heat. Checked the vent and it is clear and vacuumed out the lint collection area. I think it needs a new heating element, I changed one out before in my old dryer and that did the trick.
What next?
Related Models
Maytag PYE2000AYW Dryer - Ele
Maytag PYE2000AZW Dryer - Ele
International PYE2000GGE Dryer - Ele
International PYE2200AKW Dryer - Ele
Maytag PYE2200AYW Dryer - Ele
Maytag PYE2200AZW Dryer - Ele
Maytag PYE2300AYW Dryer - Ele
Maytag PYE2300AZW Dryer - Ele
International PYE3200AGW Dryer - Ele
Maytag PYE3200AYW Dryer - Ele
Maytag PYE3200AZW Dryer - Ele
International PYE3300AGW Dryer - Ele
International PYE3300AKW Dryer - Ele
Maytag PYE3300AYW Dryer - Ele
Maytag PYE3300AZW Dryer - Ele
Maytag PYE3360AYW Dryer - Ele
Maytag PYE4500AYQ Dryer - Ele
Maytag PYE4500AYW Dryer - Ele
Maytag PYE4500AZW Dryer - Ele
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
  #2 (permalink)
Old 10-29-2009, 07:51 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
The first thing I would do is check the circuit breakers for the dryer and make sure there is 240 VAC at the dryer wall outlet. The heating element needs 240 VAC while the motor - just 120 VAC, and if one of the two legs is missing then the dryer would not heat.
__________________
  #3 (permalink)
Old 11-02-2009, 11:19 AM
Junior Member
Default
Quote:
Well, resetting the breakers made no difference. How do I open the dryer to replace the heating element?
  #4 (permalink)
Old 11-02-2009, 04:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Do not rush with the parts. You have to have a simple multimeter to perform the diagnosis and find out which part is really bad and the first thing you should do is verify if there is 240 VAC at the wall outlet for the dryer.
In order to disassemble the dryer:
1. Pull out and remove the lint screen.
2. While lifting the front corners of the cabinet top, press a putty knife against the left and right top clips, and release them from the top. Rotate the cabinet top up and rest it against a wall.
3. Disconnect the door switch connector from the harness connector.
4. Remove the left and right screws from the inside of the cabinet front.
5. Pull the cabinet front forward slightly, lift and unhook it from the two bottom hangers, and remove the front.
6. Reach under the drum to the drive motor and push the idler wheel arm to
relieve the spring tension on the belt, then slide the belt off the motor pulley.
7. Lift the drum and remove it with the belt from the dryer
You have to check for continuity all thermostats in the heating circuit in accordance with the wiring diagram, and the heating element.
__________________
  #5 (permalink)
Old 11-02-2009, 06:28 PM
Junior Member
Default Continuity
Thanks Gene ... its quite a bit more complicated to get into than my old dryer where the back just popped off. LOL
As for 240 VAC I assume it is there since the dryer has been installed and operating in the same place for 9 yrs. Guess I'll have to go to the hardware store and get a multimeter and work through the wiring diagram.
Linda
  #6 (permalink)
Old 11-02-2009, 07:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
...As for 240 VAC I assume it is there since the dryer has been installed and operating in the same place for 9 yrs...
Linda,
If it was good 9 years ago it does not mean it's good today. Nothing last forever.
__________________
  #7 (permalink)
Old 11-03-2009, 09:05 AM
Junior Member
Talking Broken element
Linda,
Once we had unit open, we could see a break in heating element coil. Replaced the heating element and thermostat and we are back in business. Thanks so much
  #8 (permalink)
Old 11-03-2009, 05:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Linda,
I'm glad you were able to fix it. Good luck with your dryer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Performa Electric Range Smoothtop MollyGolly Oven Repair (including Ranges and Cooktops) 0 10-27-2009 06:13 PM
Maytag electric dryer heat stays on SusanMKoehler@comcast.net Dryer Repair 2 10-27-2009 02:39 PM
Maytag Electric Dryer Won't Heat ayersl Dryer Repair 2 08-24-2009 12:22 PM
maytag performa won't heat losthelp Dryer Repair 1 06-02-2009 05:10 AM
MAytag Performa Dryer dcheeks30 Dryer Repair 1 10-13-2008 02:05 PM
